Leveled on stock 16's with 285's or 265's - Chevy and GMC Duramax Diesel Forum
Sponsored by:
Old 01-17-2013, 06:50 AM   eBay Motors  #1 (permalink)
I'm looking to buy tires here soon and I am split between those two sizes for my truck. The truck is leveled and I'm worried that if I get the 265's they will be to narrow for the look, since the front wheel well is affectivly bigger now, but I'm also not sure if the 285's are the right choice. Does anyone have and advice or pictures of there trucks with those tires on it. Thanks
2006 LLY CCSB 2500HD, EFI Live tow tune, turbo back, intake.
2005LLYZF6 is offline   Reply With Quote
Old 01-17-2013, 07:31 AM   eBay Motors  #2 (permalink)
are you running the oem 245 size now? I run 265's on 16x8 wheels but my only pics are side profile and don't give any perspective to tell you if they would be too narrow for your liking. I also run stock 245's in winter time and I have the pics of both in the before/after thread that's floating around. I can track that down if you like.
2007 Chevy 2500HD "classic"
LBZ CC/SB 4x4 LT3 -- 57,xxx miles
Air Lift LoadLifter 5000 airbags; Curt E16 5th wheel hitch, TranSynd ATF
tom777 is offline   Reply With Quote
Old 01-17-2013, 07:33 AM   eBay Motors  #3 (permalink)
Baadgoat's Avatar
I've had 285s on both of my trucks leveled. Only way to go leveled on pyos IMO...both trucks are leveled on stock keys and no rubbing.
2003 CCSB LB7
EFI live w/ DSP5 by Rob | PPE Boost Valve | Custom TBs
20x10 Havoc's | Nitto Terra Grapplers | Leveled | Sleeves
Leveled Tow mirrors | 6000K HIDs | LED Tails
2005 CCSB LLY- SOLD
Baadgoat is offline   Reply With Quote
Old 01-17-2013, 07:37 AM   eBay Motors  #4 (permalink)
I actually have 285/50/20 Rockstarts with Nitto's that I do not like, they were on the truck when I bought it, I have a set of stock rims that I will be using. Baadgoat those dont look to bad at all with 285's on them.
Old 01-17-2013, 08:45 AM   eBay Motors  #5 (permalink)
RockinJW's Avatar
I'd say 285's as well, fit nicely under my leveled truck.
RockinJW is online now   Reply With Quote
Old 01-17-2013, 08:47 AM   eBay Motors  #6 (permalink)
Meyer Performance
lutzjk913's Avatar
285/75-16 ftw!!!!!
Joe
2008 CCLB LT2 DURAMAX LMM
was once stock
Special thanks to Tyler @ www.MeyerPerformance.com 812-344-4421
lutzjk913 is offline   Reply With Quote
Old 01-17-2013, 10:29 AM   eBay Motors  #7 (permalink)
pimpcey's Avatar
My truck had 265s on it when i bought it. Wasnt leveled. Then i put 10" wide rock crawler rims on it with the 265s and it rubbed only because the wheels was so wide and offset wrong. But the tires look really good on a 10" rim. Tommaro im picking up a set of pro comp wheels and 285s and maybe a little tbar cranking. ill let you know the diffrence and post pics for reffernce too
04.5 ccsb 4x4/pcv reroute/egr blocked/flowpro 4" strait pipe exhaust 3" downpipe/airbox mod/edge insight efi by underground diesel/airdog 2 165 liftpump/ppe race valve fprv/ppe stage 4 trans and converter/all on headlight mod/double 5 % tint all windows and 50% whole windshield/bed coated rockers an bumbers/10000k hid lows & fogs/transferflow 2 70 gal fuel tank/zone 6" lift/35x12.5r20 wrapped around 20x10 moto metal 956s custom front bumper with 6 kc 100 watt lights wired to factory fog light wires.high out put alternater
pimpcey is offline   Reply With Quote
Old 01-17-2013, 11:33 AM   eBay Motors  #8 (permalink)
pimpcey's Avatar
the first pic is stock wheels with 265s and the others are same tires mounted on a set of 10" wide wheels off one of my mud trucks
Old 01-17-2013, 12:05 PM   eBay Motors  #9 (permalink)
285/75/16
2006 / Chevrolet / LBZ / CCSB / 4x4
5% Tint / H2's / Nitto / Cognito UCA
Bilsteins / 5" exhaust / EFI Live
sab316 is offline   Reply With Quote
Old 04-21-2013, 08:47 PM   eBay Motors  #10 (permalink)
Here's my new combo. Coming from the stock setup, I dig it, a lot...
265 BFG ATs on Method Standards
2005 LLY CCSB 4x4
BFG 265/75-16
Method Standards
'88 1 Ton Toyota
christyle is online now   Reply With Quote
