Sponsored by Discount Tire
Old 02-16-2009, 09:10 AM   eBay Motors   #1 (permalink)
Parker Lacy
tire size
i have an 08 with a 2" leveling kit. what is the max i can fit on my truck? I am wanting to go with 33x12.5 on a 20" rim, is that do able?
Parker Lacy is offline   Reply With Quote
Old 02-16-2009, 11:35 AM   eBay Motors   #2 (permalink)
Durallymax
yes with some trimming
The "Last Minute Puller"
'03 GMC 2500HD LB7/Allison EC/SB 4x4
Suncoast, EFI Live, S400, Studs, Stock Motor
Badger Truck Pullers Association Member
Thanks to all of my sponsors
Durallymax is offline   Reply With Quote
Old 02-16-2009, 05:17 PM   eBay Motors   #3 (permalink)
Parker Lacy
ok, so just trim the plastic or is it going to rub on anything metal?
Old 02-16-2009, 05:18 PM   eBay Motors   #4 (permalink)
aggar
Smoke. It's what's cookin
aggar's Avatar
12.50 wide might be pushing it on a LMM. Also the BS might come into factor too.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058, SC Case Brace, 68mm Cheetah, EFI Live, Air Dog 150 II, Auto meter gauges and pod, EGR Blocker and FRPV shim kit, ATS dual CP3 kit, 60% Extrude hone injectors E-locker
Old 02-16-2009, 05:41 PM   eBay Motors   #5 (permalink)
omcvay
omcvay's Avatar
I ordered 18x9 -10 offset 4.35 BS and 325/60 R18 Nitto Terra Grapplers. My leveling kit will be here on Wednesday and I will install it that afternoon. The wheels and tires will be here on Friday. I will let you know how much trimming and problems I have along with some pictures if you'd like. dmaxguy2008 has almost the exact same set-up and he made it work.
'08 GMC 2500HD Z71
325/60R18 Nitto Terra Grapplers
18x9 XD Hoss
Leveling Kit
Straight Pipe
EGR Block Plate
Edge Race Evo
omcvay is offline   Reply With Quote
Old 02-17-2009, 12:59 AM   eBay Motors   #6 (permalink)
Durallymax
I dont know on the NBS trucks. On my 03 my 315/70R17s rubbed the sway bar and ripped the insulation out of the cab. But this was with the t bars at stock height
Old 02-17-2009, 03:11 AM   eBay Motors   #7 (permalink)
BUGGYS DMAX
I Had 325/60/18 And A 6 Inch Procomp And Still Rubbed In Spots. Nbs Is Hard To Clear Tires
2008 GMC 2500
6" PROCOMP LIFT GONE
COGNITO LEVELING KIT AND BILSTEINS
285/65/18 INTERCO M-16
MOTO METAL WHEELS
MBRP 5" DPF DELETE
EFI LIVE FROM MY MAN IDAHO ROB
TRANSGO JR
BUGGYS DMAX is offline   Reply With Quote
Old 02-19-2009, 08:53 PM   eBay Motors   #8 (permalink)
omcvay
omcvay's Avatar
Just a quick update. I installed the 325/60r18s today and had to trim quite a bit. It was so worth it. It looks awesome. I can post some pictures if anyone is interested.
'08 GMC 2500HD Z71
18x9 XD Hoss
Leveling Kit
Straight Pipe
EGR Block Plate
Edge Race Evo
Old 02-19-2009, 09:29 PM   eBay Motors   #9 (permalink)
maxxflip
maxxflip's Avatar
they will fit with trimming
08 LMM
Tuned by ʍʍlʍʍ
maxxflip is offline   Reply With Quote
Old 03-09-2009, 10:49 PM   eBay Motors   #10 (permalink)
dmaxguy2008
dmaxguy2008's Avatar
looks sweet man!!!!!
2008 Silverado LMM CC SB EFILIVE bullet hole/s in hood Snake oil fuel additive with adamantium wheel studs
Close range Sniper For Hire
-Cole-
dmaxguy2008 is offline   Reply With Quote
