Sponsored by Discount Tire
Old 02-20-2009, 09:10 AM   eBay Motors   #1 (permalink)
fishinmachine
New tires
My first post here, just graduated from my Bronco (I blew it up) to an 04 Duramax(best thing I ever did). After this winter we had up here the stck tires have to go. I'm lokking at 305/70-16's, but will 315/75/16's fit under it if I crank teh bars up? I'm running an 04 Crew 4x4 2500HD.
Thanks guys
If your wearing a shirt that says 'I'm with Stupid" when you're by yourself, then i'd say that's about right.
fishinmachine is offline   Reply With Quote
Old 02-20-2009, 09:45 AM   eBay Motors   #2 (permalink)
codyt
they will probably fit if you trim alot but i wouldnt want to crank the bars that high. i would get ahold of norcal nick he will hook you up with what you need to do it the right way.
2005 Chevy 2500 HD
6.6 Duramax LLY 57000 miles
Ext. Cab, Short Bed. White
Stage IV SC, EFI LIVE.
5" MBRP turbo back exhaust
Raptor 150 GPH lift pump
truxxx leveling/lift kit, 3 in the front 2" in the rear
305/70 16 Mastercraft courser MT tires (33X12.5)
Pro Comp xtreme alloy 6001 series wheels.
PPE Tie Rod Sleeves and Pitman and Idler arm Supports
493 HP and 973 Ft. Lb. Torque 4-5-09
codyt is offline   Reply With Quote
Old 02-20-2009, 09:52 PM   eBay Motors   #3 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
It will be close. Your better off running a 285 its not that mutch smaller than them.
Jason
Old 02-20-2009, 09:57 PM   eBay Motors   #4 (permalink)
timespentsearching
timespentsearching's Avatar
your not going to fit anything bigger the 285 on stock rims as well
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
