I have been looking at new tires and bigger of course but don't want to lower my RPMs too much when towing, I'm not to concerned about every day driving but I came across this calculator that will allow you too put in such parameters as
Final Gear Ratio:
Transmission Gearing Ratio:
Tire Diameter in Inches:
Tire Growth Factor in Inches Per MPH Squared:
Transmission Slip Factors:
Transmission Efficiency(%)
and then calculate an RPM. This would be useful when making any decision to go bigger with tires. Here is the web site if anyone is interested. RPM Range Computation
__________________ 2006, 2500HD, Extended Cab, Short bed, 4X4, LBZ, Gray-stone Metallic, MBRP 4" down pipe back ,no cat, Edge juice w/ Attitude, Banks Ram air intake with Super Scoop, AEM Water Methanol Injection, EGR block and finger stick. BFG All Terrain KO 265/75/16. |
