Sponsored by Discount Tire
03-02-2009, 06:38 AM
eBay Motors
#1 (permalink )
what tire pressure
what is recommended tire pressure I just got a 2003 2500 hd 4x4 extended cab and the door stickesr is gone it has stock 245/75/16
03-02-2009, 06:42 AM
eBay Motors
#2 (permalink )
Tire Pressures
I run 60 front and 80 rear when pulling on 4 lane hwys.
__________________ 2005 Silverado CCSB LT 4X4 LLY
Rear DVD,AstroStart AutoStart,
NiteHawk Colour Matched Hard Tonneau,
Chrome Nerf Bars ,Tekonsha Prodigy Brake Controller
Nitrogen Filled Tires,Onstar, Magellan Roadmate 1412 GPS
Finally Completed LBZ MP, PCV Re-route, Plugged resonator
18' 4 Place Enclosed Roadmaster Trailer
2004 Harley Ultra Classic FLHTCUI
2003 Titanium 32E37DS
03-02-2009, 06:43 AM
eBay Motors
#3 (permalink )
Yeah, That guy!!!!!
Read the side wall of the tire it will say max inflation on the side. I run them at max on road trips and around 10psi less in town.
06 2500 CREW CAB 4X4 LBZ LOONNGGGGG BED 4" DIAMOND EYE EXHAUST, DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....Its Coming.....EFI LIVE..... WORK RIG
DPF GONE!!!QUADZILLA STEALTH II, K&N FILTER, MAF CLEANER IN BED
HERE TOO....... This is not only your forum you have to share it with 28,000 others
03-02-2009, 06:54 AM
eBay Motors
#4 (permalink )
The load range will also help you determine what tire inflation pressure should be.
03-02-2009, 07:14 AM
eBay Motors
#5 (permalink )
I run 50 in front and 65-70 in back when I am not hauling. When I am hauling I bump that up to 65 in the front and 80 in the back to improve load handling and mileage under a load...
03-02-2009, 07:16 AM
eBay Motors
#6 (permalink )
80 in the back 60 in the front
__________________ 2007.5 Chevrolet LMM
Leveling Kit with 275/65/20 Cooper Zeon LTZ tires
20" Pro Comp Alloy Wheels
Straight pipe turbo back exhaust from Meyer Performance
Quadzilla Stealth II on 50hp
03-02-2009, 07:23 AM
eBay Motors
#7 (permalink )
ASE Certified PartsWhore
check the sticker on your drivers door jamb.
03-02-2009, 12:27 PM
eBay Motors
#8 (permalink )
Originally Posted by
bnkrupt check the sticker on your drivers door jamb.
Sticker is gone someone tore it off
Thread Tools Display Modes Linear Mode
