Sponsored by Discount Tire
Old 03-10-2009, 05:06 PM   eBay Motors   #1 (permalink)
SNAFU
Tire, Leveling and rim question...
Ok This past weekend I was in Houston at the Raceway Park watching the ARDL races, which were pretty damn awesome, and seen a Dick Cepek trailer and decided in my inebriated state to smmmmoooothly walk over and pick the mind of the guy behind the tire stacks..... But I think when I left I had more questions than answers.... anyway this is what I have in mind for my 08 and I need some feedback from you fellows out there that has already did the trial and error.
The players:
17x9 DC-1 Black
Part #
979481
Size
17X9
Appx. Wt.
28
Bolt Pattern
8-6.5
Backspace
4.53”
offset
-12mm
Max Load
3,400
Part#
23274
Tire Size
33X12.50R17LT
serv. desc.
114Q
load range
D
Max Load
2,600
1st question: is the offset/backspace the correct one to get or how do you figure it??
2nd Question: I also want to add the Cognito levling kit. I need to know when I put the leveling kit on if it raises the front in up higher than the rear end, giving it a wedge look? or will i have to add some blocks to the rear axle to actually level the thing back out??
I am not looking for a skyscraper truck just want some meat on the ground under me. Any feedback will be much appreciated!!
Black '08 Chevy LTZ HD2500 Crew Cab Short Box z71 Duramax 6.6, Allison 6 speed Auto/Manuel Bone Stock No Up Grades at this time....
1st upgrade was a small one :-D
Nerf Bars added.
( reserve the right to change this part at any time )
1st Diesel I have ever owned AND LOVIN' EVERY MINUTE OF IT!!!!!!!
SNAFU is offline   Reply With Quote
Old 03-10-2009, 05:20 PM   eBay Motors   #2 (permalink)
SCDually
SCDually's Avatar
The leveling kit will allow the front end to be level with the rear without touching the rear suspension at all; and without the "California lean". I have heard of people installing blocks at the same time, but I assume they were trying to fit big tires. If you search, I think there have been some recent posts of before/after pics of leveling kits
I can't help with the backspacing question, but there are plenty of tire gurus on here that will chime in
2009 GMC 3500 Dually 4x4; Leveling Kit, Titan Fuel Tank, Sprayed Bedliner, Firestone Airbags, BFG 265/70R17 on stock rims
Former: 1995 GMC Sierra K1500
SCDually is offline   Reply With Quote
Old 03-10-2009, 05:23 PM   eBay Motors   #3 (permalink)
SNAFU
Thank you sir. That makes me feel a lot better knowing it won't have that ... as you called it "California Lean".
Nerf Bars added.
Old 03-10-2009, 09:44 PM   eBay Motors   #4 (permalink)
caramon
caramon's Avatar
I'm still unclear how to figure the offset/backspacing thing is measured and the guy at the local Americas Tire was going to explain it, but I sidetracked him with more questions and before I knew it, I was out of the store.
I've also seen a few links around here to explain it, but the gist of it is, that you should go with a positive offset rim which works out to be around a 5"+ backspacing. The rims I'm looking at for instance are +18mm. The reason is the closer you are to 0 or negative offset, the more the tire/rim combo is going to stick out from stock position. The stock offset is +25mm with I think a 5.75inch backspace. I think you can probably figure out the math from there
2007.5 LMM Chevy Silverado CC SB 4x4
Edge Evolution Race
Deezee 5" Oval Nerf bars
Xtreme Coatings Bed Liner
Front windows tinted to match the back
Ready Lift leveling kit
Nitto Terra Grappler 295/70/17
MB V-Drive 17" wheels
Magnaflo 4" Turbo back exhaust
My Gallery :cool
caramon is offline   Reply With Quote
Old 03-10-2009, 10:19 PM   eBay Motors   #5 (permalink)
AlligatorPerformance
AlligatorPerformance's Avatar
I think you will have some rubbing issues with that offset. You need to go with a wheel with a positive offset and more backspacing.
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
AlligatorPerformance is offline   Reply With Quote
Old 03-10-2009, 10:26 PM   eBay Motors   #6 (permalink)
Toyaholic
Toyaholic's Avatar
This will help explain:
https://www.rsracing.com/tech-wheel.html#backspace
2008 LTZ CrewCab Standard Box
Pace Edwards Full Metal JackRabbit cover
4" Putco Wheel to Wheel Stepbars
CST 6" Lift - Quadzilla S2 - MBRP 5" (DPF back)
20"x10" Ion Forged rims w/ 325/60/20 Nitto Terra Grapplers
Toyaholic is offline   Reply With Quote
Old 03-11-2009, 11:39 AM   eBay Motors   #7 (permalink)
SNAFU
Thanks Toya that is a great informational page!! helps clear some stuff up... Time to pull out the ole slide rule, wooden tape measure and go old skool on this project!!
HOOOAAHHHH
Nerf Bars added.
Old 03-11-2009, 12:50 PM   eBay Motors   #8 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
i would stay with a +12-+18offset instead of the - offset like he suggested,if not you will have fitment issues with the 33's..thats my experience with'em.
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 03-11-2009, 12:52 PM   eBay Motors   #9 (permalink)
WFO Duramax LBZ
WFO Duramax LBZ's Avatar
Also any recommendations on good strong wheels
William W. "Dub Dub"
2007 Chevy LBZ CC/SB 4X4
My Mods Thanks to Chad Hall @ Alligator Performance:
AFE Drop in filter in a PPE Modified Air Box, Edge Evo RACE, BD Manifold and a 5" DP Back Magnaflow w/ 6" RBP Tip
Still in boxes!!
Banks Ram Air, Super Scoop, Transgo Jr, EGR Blocker, Diamond Eye Turbo Direct Pipe, Air Dog 150 II
My Other Toy:http://i669.photobucket.com/albums/v...7/DSC00082.jpg
WFO Duramax LBZ is offline   Reply With Quote
Old 03-11-2009, 12:55 PM   eBay Motors   #10 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
with the leveling kit you can clear 33's if you keep the offset positive,it will tuck the tires under the truck but not change the apperence that much vs them sticking out with the negative offset..
WFO LBZ,
unless you go with Forged wheels thats about as strong as it gets.
James
Business Truck
DD/Beat Around
Economy Saver
