I have an 07 NBS duramax and am looking at getting different rims. I'm pretty interested in a set of xd hoss 18x9's and would run a 325/60 nitto terra grappler. My question is which offset should I go with. I have a choice between -12mm 4.5" BS. or +18mm 5.71" BS, and I dont want my tires to be stickin to far out so I'm thinking I should go with the +18, but I do like the look of a deeper dished rim. My pickup has a leveling kit in the front, and I have airbags in the back. I would appreciate any info anyone would have, and if sombody has pics, that would help to.
Thanks
__________________ 2007.5 Duramax CCSB, Black, EFI Live, 4" Magnaflow turbo back DPF Delete and cobalt gauges from Nate @ Performance Truck Products! PPE air box mod, EGR Blocked, 20% tint, Readylift leveling kit, Firestone Airbags, Transgo jr
That tire is 33.5" OD.
You'll be hard pressed to make it fit with a 2" lift.
Not to mention it is 13" wide too. Be prepared to do some cutting!
The positive offset will be closer to stock. Those tires/wheels will hang out HUGE if you go negative off-set.
__________________ Pictures: http://www.duramaxforum.com/forum/wh...look-sexy.html 2007 LBZ 2500HD CC SB 4x4
Leer canopy, Aries Oval step bars, 18" AR Cannons wrapped with General Grabber HTS 275/65R18's, Bushwacker Pocket Flares, and 2" drop shackles in the rear
Love this truck....HATE the fuel economy yea yea, I know it's a truck, and YES I want the same mpg as a Civic
Ok thanks. Right now I am running 17x10's with I believe -12 offset, with a 285/70-17, which is 1.5" narrower, and a little over 1/2" shorter than 325/60-18's, so I figured maybe if I get a positive offset rim, I could go a little bigger on the tire??? Right now my tires will rub slightly when turned all the way.
Thanks
Trent
+18 is close to stock!! If i remember +25 is perfect (stock). I still see it hard to fit them, but with the correct trimming anything is possible
__________________ Jim
4" Magnaflow Exhaust
Modified factory air box
Ported Turbo Horn
EFI LIVE V2 www.performancetruckproducts.com
An offset close zero I would think would work and im runnin 305/70/r17's right now with just the tbars carnked and those are bigger than the ones your lookin at. I think you wont have a problem clearin them. Also since your lookin at 18x9's i dont think having a negative offset would be that bad. But I think with that positive offset you could clear them no problem
__________________ 2006 CCSB 4x4 LBZ
MODS: EFI LIVE-MITUSA LIFT PUMP-DIAMOND EYE DP-BD MANIFOLD-5" STRAIGHT PIPE-PACBRAKE SLEEVES-BANKS RAM AIR INTAKE-TRACTION BARS (BUILT BY DMAX15)-DI PROCOL PYRO, BOOST, AND DP
Alright thanks alot for your help guys. I would probably be better off with the positive offset, but I like the look of a deeper offset rim and am worried it might look funny if I go with the positive. We'll see.
Thanks
Trent
