Sponsored by Discount Tire
Old 03-15-2009, 08:51 AM   eBay Motors   #1 (permalink)
duramax9878
duramax9878's Avatar
295 and 305s
how r some of you guys getting the 295 or 305s on your trucks id like to get bigger tires next time and wondering what i have to do to get them to fit the 285 i just did some trimming and didnt crank the bars any so what did u guys do
Danny
2006 LBZ Chevy with 5in. single stack,some add on, and more coming soon.[/url]
duramax9878 is offline   Reply With Quote
Old 03-15-2009, 08:58 AM   eBay Motors   #2 (permalink)
marbles72
I did a cognito level front torsion,we put a rake too her in the back 3'' block
2006 gmc slt,full bore exhaust maniflod,leather,dee zee nerf bars,Diamondback hd tonneu cover,cloud rider mud flaps ,trans go jr with bd valve body, cognito level installed uca , ppe tie rod sleeves,atx teflon,pro comp shocks edge evoloution A/T.295/70/17 nitto terra grapplers: NOW WHERE ARE THE CANADIAN TRANNY BUILDERS
marbles72 is offline   Reply With Quote
Old 03-15-2009, 09:08 AM   eBay Motors   #3 (permalink)
duramax9878
did u install the kit your self
Danny
Old 03-15-2009, 09:19 AM   eBay Motors   #4 (permalink)
marbles72
no I swing wrenches for a living on big boilers and heating system,It can be done at hoe but I paid to have itinstalled,I had new torsion keys put in as well,the old ones had to be cut out
Old 03-15-2009, 09:42 AM   eBay Motors   #5 (permalink)
duramax9878
what about like a ready lift type or torsion bar key
Danny
Old 03-15-2009, 10:03 AM   eBay Motors   #6 (permalink)
SzymoDmax
SzymoDmax's Avatar
they work but without the new upper control arm they put to much on an angle on the upper ball joint...just my opinion, i know some are running without them, but i wouldn't. puts a lot of stress on it. also keep an eye on your cv shaft. to much on an angle on it and you'll be buying new ones of those to, on a regular basis
2004 chevy 2500hd with lly
efi live & dps 5 switch tuned by idahorob
mbrp straight piped 4"duals 6" tips
egr blocker plate, lbz mouth piece
06, grill and hood, sunroof and many more
Moto Metal 950 wheels with 285/75/16 BFG'S
Truck#2 1983 chevy 4x4 with 5.9 12 valve
Let men marry men and women marry woman...in 3 more generations there will be no more democrates
SzymoDmax is offline   Reply With Quote
Old 03-15-2009, 10:14 AM   eBay Motors   #7 (permalink)
duramax9878
thanks who makes a good leveling kit
Danny
Old 03-15-2009, 10:59 AM   eBay Motors   #8 (permalink)
marbles72
cognito,seems to e the way to gowith these trucks
Old 03-15-2009, 11:10 AM   eBay Motors   #9 (permalink)
aggar
Smoke. It's what's cookin
aggar's Avatar
Contact Nor-cal Nick. he can set you up with a good leveling kit. Won't steer you wrong. Also for the better ride if you crank your bars, you'll need the shock extension bracket or longer shocks. The shorter shocks will not allow full travel and will bottom out and make the ride a little harsh. I'm running 295's on H2's and no rubbing but my bars are prolly 3/4 the way up and longer shocks. Does ride a little stiffer but not too bad.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058, SC Case Brace, 68mm Cheetah, EFI Live, Air Dog 150 II, Auto meter gauges and pod, EGR Blocker and FRPV shim kit, ATS dual CP3 kit, 60% Extrude hone injectors E-locker
