Sponsored by Discount Tire
Old 05-31-2009, 04:48 PM   eBay Motors   #1 (permalink)
penzance23
penzance23's Avatar
Larger tires increase miles on truck not on odometer? not mpg
If I run 285's instead of the stock 245's will the odometer be off? Am I really putting on more miles on the truck than is actually showing on the odometer? In theory, it would seem that I am, right?
Jason
penzance23 is offline   Reply With Quote
Old 05-31-2009, 04:53 PM   eBay Motors   #2 (permalink)
sofakingbad
sofakingbad's Avatar
yes it will be off.....mine is.
06 GMC Lbz 4x4 -sold
05 Cummins 4x4
01 Cummins 2wd 6speed
sofakingbad is offline   Reply With Quote
Old 05-31-2009, 04:58 PM   eBay Motors   #3 (permalink)
ankersen557
I just went from 265 to 285 my mph is about 2 faster then the speedo. This is going off a gps unit. My milage is the same. 1 mile on odometer is 1 mile on gps. This is just from watching my garmin gps.
2008 CC LTZ 4x4 Greystone Metallic, Edge Juice w/ attitude,DPF Back MBRP Exhaust, Alpine drop down 10in DVD, LINEX Bedliner, Window visors all around, 15% Tint all around, T-bars cranked 2in to level front(dealership done), HID 10000k,chrome 6in oval nerf bars,B&W turnover ball, Ultra Goliath +20mm offset 17-8 on 285-70-17 BFG ATs
EDJE JUICE WITH ATTITUDE FOR SALE $400.00 shipped OR BEST RESONABLE OFFER
www.HUSKERDIESEL.com[url]
ankersen557 is offline   Reply With Quote
Old 05-31-2009, 05:35 PM   eBay Motors   #4 (permalink)
motox92
motox92's Avatar
Did your fuel mileage change from the 265 to 285?
2001 Silverado.
Stock drivetrain.
motox92 is offline   Reply With Quote
Old 05-31-2009, 05:38 PM   eBay Motors   #5 (permalink)
NVMYLLY
NVMYLLY's Avatar
With a tuner you can USUALLY adjust speedo for larger tires.
I am assuming that will correct the odometer from being 'off'
--2004.5 GMC 2500HD 4x4--
Hog 4" SS Turboback w/6" SS Polished Tip, AFE Stage II Intake, EGR Block and Finger Stick, Resonator Plugged, PPE Fuel Release Valve Shim Kit, PPE Tie Rod Sleeves, TTS Dual Lift Pumps, Quadzilla Stealth2
Pioneer In Dash DVD, CD, MP3, and NAV, Boston S60 Internals all around, 10" JL W3 Sub, JL 500/1 Amp, Custom Under-Seat Non-Ported Box, Triple Pillar w/Autometer Sport Comp II (EGT, Oil Temp, BOOST), 15% Tint Up Front
285's BFG A/T, ArmorThane Spray-in Bedliner, Extang R/T Tonneau Cover, Black Step Tubes, Recon LED Big Rig Kit, Red Varad Expansion LEDs, Recon LED Smoked Cab Lights, Black LED Third Brake Light, LED Line of Fire Under Tailgate, Cowl Hood w/Duramax Emblem:cool
NVMYLLY is offline   Reply With Quote
Old 05-31-2009, 06:39 PM   eBay Motors   #6 (permalink)
ankersen557
My milage dropped about 2 mpg this tank so far. I have only have them for about a hundred miles. And that is going off the DIC compared to what I usally get on the DIC. Hopefully it gets better.
Old 05-31-2009, 06:43 PM   eBay Motors   #7 (permalink)
Dmax7511
DURAMAX!
Dmax7511's Avatar
ok im sry im still a newb what DIC stand for ?
2007 White Lbz CC 4x4 LT
Lil Something Something Under The Hood , & In The ECM
20" Kmc Xd Hoss On 35" Nitto Mud Grappler's
6" Procomp Lift
Egr Blocked
Transgo Jr
4 Inch MBRP Turbo Back
10,000k HID"s Headlights And Fogs
www.HuskerDiesel.com
www.AlligatorPerformance.com
Dmax7511 is offline   Reply With Quote
Old 05-31-2009, 06:55 PM   eBay Motors   #8 (permalink)
motox92
motox92's Avatar
Driver info center
2001 Silverado.
Stock drivetrain.
Old 05-31-2009, 07:25 PM   eBay Motors   #9 (permalink)
tate07lbz
tate07lbz's Avatar
if you are running bigger tires you will be putting less miles on your truck.
07.5 chevy LMM quad cab stock for now. my wife doesnt need any more power.
07 ChevyClassic LBZ. Quadzilla stealth 2 tuner, stock straight piped,K&N cool air intake,lots of chrome looking for a new set of wheels
04 chevy lb7 dually hypertech tuner, straight pipe, Dew eze hay bed
tate07lbz is offline   Reply With Quote
Old 05-31-2009, 07:57 PM   eBay Motors   #10 (permalink)
bowhunternkbay
bowhunternkbay's Avatar
Larger tires will cause your speedo to be off...Since they are larger in circumference, it takes less revolutions to travel the same distance.All this can be corrected by most programmers/tuners. Larger tires also weigh more than smaller tires and consequently effect mileage.(for the worse).
'06 2500 HD CC/SB
BullyDog TripleDog
AiRaid CAI
MBRP 4" Turboback
Goodyear Silent Armor LT 285/75R16
Blocked,Fingered,Rerouted,Sleeved and Plugged
www.DiscountTireDirect.com
bowhunternkbay is offline   Reply With Quote
