Sponsored by Discount Tire
Old 06-21-2009, 08:08 PM   eBay Motors   #1 (permalink)
Specialized89
Specialized89's Avatar
Small Wheel Problem
Hey guys, the bolts for the center caps on my wheels have mostly broken off.
The center caps require two bolts two hold them on properly or else they just kind of sit there loose.
I was wondering if anyone could give a tip on getting the broken bolts out.
They are rusting and the tiny piece that is sticking out is somewhat bent and I am having a hard time getting the E-Z out bits to grab.
You can see the three broken bolts in this picture.
Thanks
2004.5 Chevrolet Crew Cab Short Box.
6.6 LLY/Allison 1000 5 speed.
4'' of lift w/ Yokohama Geolanders.
aFe intake (stage 1)
Unknown brand 4" exhaust.
aFe Mouth Piece.
Specialized89 is offline   Reply With Quote
Old 06-21-2009, 08:20 PM   eBay Motors   #2 (permalink)
Ironman070809
Ironman070809's Avatar
maybe soak the hell out of em with pb blast and try a left handed drill bit
05 Duramax LLY
Bullydog Tripledog(Crazy Larry)
w/ outlook monitor
Ironman070809 is offline   Reply With Quote
Old 06-21-2009, 08:35 PM   eBay Motors   #3 (permalink)
maxxflip
maxxflip's Avatar
X2 on the left hand drill bit, may be a little heat on the inside of the hub. When you do get them out use some anti-seize on them before you put them back in.
Where in AB are you?
08 LMM
Tuned by ʍʍlʍʍ
maxxflip is offline   Reply With Quote
Old 06-21-2009, 08:39 PM   eBay Motors   #4 (permalink)
twinturbo3150
Banned
use a center punch, then start with the smallest drill bit working your way up to a bigger drill bit. Works for me every time
twinturbo3150 is online now   Reply With Quote
Old 06-21-2009, 10:20 PM   eBay Motors   #5 (permalink)
Specialized89
Okay thanks for the info guys.
maxxflip: I am in Calgary
aFe Mouth Piece.
Old 06-22-2009, 12:45 AM   eBay Motors   #6 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Worse thing would be you have to drill them out then retap. The wheels aluminum so you could always turn the center cap and drill new holes on the 4 open sections on the wheel
Jason
