If you cant find any steel ones I know where you can find some tough aluminum ones. I beat on them and even had the truck 4-5' high jumping a heavy ford diesel and they never broke or showed signs of wear after years.
__________________ 2002 GMC LB7
those would work them. ya fred makes steel one but are 320 and i havce emailed him twice and no email back, i was looking for other ones beside his. i just dont wnat to break them towing you know
__________________ Pickup: 03 GMC 2500HD EXT Cab Long Box
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
Freddy how much (+) do you need? I had the half inch aluminum spacers on my front end because of the offset of the rims, and it was fine. Over half inch id get new lugnuts.
__________________ Brian, 19, 06 LBZ, EFILive, MM Diesel Performance, Alligator Performance, Suncoast, TTS, Cognito, High Tech Turbo, PPE, Magnaflow540rwhp/1000tq. 12.64/107.52
want to do 1.5-2 inches in the rear to set them more even to the front.
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
The aluminium used in 99.9% of all wheel spacers is 6061-T6 grade. It is 1.5 time stronger than mild steel, lighter and doesnt rust. It is the same grade aluminium used in most wheels. You can run them and feel confident that they are safe.
__________________ 05' LLY CC/SB, PPE Standard, MBRP SS 4", BD Power Manifold, Autometer Phantom 2 Pyro and Boost, Kennedy fingered n plugged, cat grew legs, Belltech 1/3 drop, Michelin LTX M/S 265/75/16, Homemade 2-stage Water/Methanol w/ 220psi pump.
Rock it till it sounds expensive!
