My bet is the leveling kit is causing the insane hop and toe in. Even when I had stock wheels, the leveling keys were hurting me bad. I have sleeves and braces, BTW. As soon as I went to lower than stock all of my issues disappeared. It's a hard choice for some to make. Have it lifted up and looking sick, or have it low and fast. The only way around the issue is to get a real deal lift that relocates the front suspension and keeps the tie rods level.
__________________ 06 Chevy LBZ/Allison 4x4 EFILive & DSP5, Suncoast IV w/1054, Suncoast Tcase brace, MA pump rub fix, PPE lift pump, AEM Intake, shimmed fprv, ported rail fittings, 4"-5" Grandrock/MBRP, torsion bolts removed, 4" drop shackles, stock turbo, stock wheels, Autometer GS boost/pyro, Aeroforce scangauge, PPE sleeves, Cognito pitman/idler braces, 8k HIDs, Recon LED tails & smoked 3rd brake, Pioneer DVD, 98,000 miles and counting 12.60 @ 105.41 mph #15---Top 25 Fastest Stock Duramax's Keystone 8 Luggers Videos
X2^^^^^^^^
__________________ -2004 LB7, Ext. Cab S/B, LT
-6" Tuff Country Suspension Lift
-35" Toyo Open Country M/T
-18x9 KMC XD MONSTERS (Black)
-PPE Standard Xcelerator
-Auto Meter Cobalt Gauges Pyro/Boost
-AEM Brute Force Air Intake
-MBRP 4" Straight Pipe Exhaust w/ MBRP 5" Black Tip
-Buckstop Front/Rear Bumpers w/PIAA 520 Fogs WWW.ALLIGATORPERFORMANCE.COM WWW.MYSPACE.COM/ANTION
The only true suspension lift are the ones that can drop the front diff 7" instead of 5"
You can go fast with a lifted truck, but to me its not a good idea.
__________________ Brian. LBZ fitted with one off parts.
ABQ Diesel Dragz March 20th, ABQ, NM gattes at 8am.
Agreed... Its fun trying but its a pain in the ass and just puts more strain on everything when lifted...
04.5' LLY 4x4 lifted CC S/B - EFI Live ATS Diesel Performance, MBRP, S&B, DDP, Autometer, RBP, Evolved MS
I have 35's and my truck doesnt hop one bit when i do boosted launches and all i have are sleeves just in hops of saving some time till we do everything heavy duty ! I agree if you have your torsions cranked that would most likely be my guess!
__________________ 2006 Duramax LBZ, 6" Pro Comp Lift W/ Dual Fox Shocks W/ Resevoirs, 4" Maganflow W/ 6" RBP Tip, 35" TOYO's On 18's, 2 10" JL Audio Subs,Transgo Jr Shift Kit, Evo Race, Raptor 150 GPH Pump!
