Sponsored by Discount Tire
Old 07-16-2009, 06:52 PM   eBay Motors   #1 (permalink)
dordtrecht5
dordtrecht5's Avatar
Front tires worn poorly
Here is my predicament:
About 5,000 miles ago I had my front aligned at a Firestone Store. I was charged like $150 with a 6 month/6,000 miles warranty. I looked at the spec sheet and they got the alignment very close. I can't remember how it was measured, but it seemed like it was within 1/1,000 of spec. Perhaps it was 1/10, I can't remember. What I do remember was it was extremely close to spec.
I had them rotate tires (first rotation and only) as well and check air pressure to 60lbs. It rides sweet at that rating. However, a couple of weeks ago, I went to towing and cranked up the pressure to 80lbs. as the tire calls for on the sidewall and have left it there.
The other day, I was walking around the truck just looking things over and noticed that both front tires are worn probably twice as much as the inside, and I would call these tires ruined because they will never wear evenly again.
What do I do? Take them to Firestone and ask for another alignment (which I am planning to do)? Do I ask them to replace the tires with new? What do I have to stand on as far as what they will replace and not?
Dallas Crist
2006 Chevy 2500 HD LBZ RCLB 4x4
6" BLACK stack; CAI; PPE Lift Pump; PCV Reroute; PPE Tie Rod Sleeves; EGR Block Plate; TransGo Jr.; Stanadyne Performance; Amsoil;
Best 1/4 13.41@102.8 (early summer '09); Best 1/8 8.09@87 (Fall '09)
EFILive by Husker Diesel: name that tune--DallasCleanHotv.1
Got Cheese? Work RAT!
dordtrecht5 is offline   Reply With Quote
Old 07-16-2009, 06:58 PM   eBay Motors   #2 (permalink)
timespentsearching
timespentsearching's Avatar
how much are the Tbars cranked up?
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 07-16-2009, 07:09 PM   eBay Motors   #3 (permalink)
seth999
Duramax Forum Moderator
seth999's Avatar
you might take a look at your pitman and idler arm if the are worn it will not hold toe and will cause major wear problems no matter how many allignment jobs you have done and the arms tend to wear fast due to the design
DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
seth999 is offline   Reply With Quote
Old 07-16-2009, 07:29 PM   eBay Motors   #4 (permalink)
2004duramaxLB7
2004duramaxLB7's Avatar
i just had a thread about this recently also. im having the same problem.
2004 3500 LB7 4x4 Dually, X-fab pre runner, 3 hella 500's, custom smoked tailights, 4 inch magnaflow, K&N cold air intake, triple pillar gauges, airdog 150, PPE boost valve, Stage IV suncoast trans. Danville sleeves, Danville tuned EFI live.
532hp & 1025tq. on danville's rollers
FOR SALE: MY TRUCK..$24,000obo
2004duramaxLB7 is offline   Reply With Quote
Old 07-16-2009, 07:30 PM   eBay Motors   #5 (permalink)
2004duramaxLB7
heres my thread...
help..front tires wearing extremely fast!!
Old 07-16-2009, 07:35 PM   eBay Motors   #6 (permalink)
dordtrecht5
none, never messed with them
Dallas Crist
Old 07-16-2009, 07:38 PM   eBay Motors   #7 (permalink)
2004duramaxLB7
look at you bump stops and see if its laying on them. my buddys 2wd 07 is sitting on them and so is mine and both of us never touched the T- bars.
Old 07-16-2009, 07:41 PM   eBay Motors   #8 (permalink)
2004duramaxLB7
heres my theory...since the front end cant flex due to the bump stops being bottomed out, when cornering, the tires will take the stress instead of the suspension soaking it up. its pretty much like having no suspension at all.
Old 07-16-2009, 07:41 PM   eBay Motors   #9 (permalink)
dordtrecht5
I was wondering about this...um...i did a couple of 4 wheel launches!!
Okay, so will the braces cure the problem, or new ones with braces added?
Dallas Crist
Old 07-16-2009, 07:43 PM   eBay Motors   #10 (permalink)
dordtrecht5
Also noticed that it wanders on the highway a little. It stays straight when you point it, doesn't pull to one side or the other, just kinda wanders around a little.
Dallas Crist
