TPMS set point change - Chevy and GMC Duramax Diesel Forum
Sponsored by:
post #1 of 46 (permalink) Old 11-25-2013, 06:40 AM Thread Starter
I am buying a 2011 GMC Sierra 2500 Denali 4x4 LML this week. It has the stock Badyear 265/60/20s on it. I am going to be putting on some 305/55/20s in the next 2-3 weeks. I want to get the dealer to lower the TPMS set points. The new tires I am going with are load E, 65PSI max. What should I have the TPMS set points changed to?
Thanks for the advice!
mrploww is offline
post #2 of 46 (permalink) Old 11-25-2013, 06:42 AM
Taking the Long Way Home
FC5452's Avatar
Send a message via AIM to FC5452
TPMS has a +/- 10 pound trip point
S468 with some fuel and a Tuna or two
MY Build
Need or Want Tuning for your Duramax, click Below
FC5452 is offline
post #3 of 46 (permalink) Old 11-25-2013, 06:45 AM
crazycrew's Avatar
My buddy took his T2 home one day and reprogrammed mine to 35psi for me! Charged me $20. Well worth it IMO as I only run 42 psi in my tires!
BROOKS LANDRY
2003 CCSB 2wd
My New Project
Instagram: brolandry
One Big Ass Mistake America
U Can't Cure Stupid
Shop @ the DMAXstore.com
crazycrew is offline
post #4 of 46 (permalink) Old 11-25-2013, 11:49 AM
g35_83's Avatar
I had the dealer set mine to 55 when I changed tires. I do change my pressure based on whether I'm towing or not and haven't seen a tire light yet.
2016 GMC Denali 3500HD SRW CCSB LML
Stock Powertrain | Morimito XB Fogs | WeatherTech Mats
2011 GMC Sierra 2500HD CCSB LML - SOLD
ECM/TCM tuned by Kory Willis @PPEI | Fass 150 Titanium w/ sump | 5" Flo-Pro w/ FTE Resonator
Edge Insight CS w/ pyro | Bilstein 5100's | Goodyear DuraTrac 285/60R20 | WeatherTech Mats
g35_83 is offline
post #5 of 46 (permalink) Old 11-25-2013, 12:19 PM
Is it +/- 10 or +/-5 for a total range of of 10psi?
I ask, because I think I have a 50psi set point and the light comes on at 45 and goes off at 55. Since I run 50 psi, I wish I had a lower 40 or 45 set point, my light comes on when the tires are cold and goes off while driving.
To the OP I would think you want either a 45 or 50psi set point or 5-10 psi lower then what you are going to drive around at unloaded.
08 2500 CCSB SLE 4x4
EFI live-dsp5, Edge Evo(for gauges), ADII 165, 3" D.P., MBRP 4" SS cool duals-DPF deleted, built trans., 4.10 gears, 315/70/17 on H2's(Summer) 285/75/16 on PYO's (Winter), All Season brace.
altamate is offline
post #6 of 46 (permalink) Old 11-25-2013, 05:34 PM
How do you lower the range? My dealership said they could not do it. I have 305/55/20 Terra Grapplers and I want to run about 40-45 psi without the light coming on.
2013 Silverado HD:
Black 4x4 Crew LTZ
| Zone | BMF Novakane Stealth | Nitto Trails | SuperChips | Amp Research | JL Audio |
Jaxter is offline
post #7 of 46 (permalink) Old 11-25-2013, 05:44 PM
TyP
They just need to use a tech2 scan tool and they can lower the range. I have done it many times at our shop.
TyP is offline
post #8 of 46 (permalink) Old 11-25-2013, 05:49 PM
FC5452's Avatar
The over under is defendant on how it was calibrated from factory, based in wheel size and tire rating. If the dealer won't adjust find one that will or someone with a tech 2. It's a 5 minute deal.
Sent from AutoGuide.com App
MY Build
FC5452 is offline
post #9 of 46 (permalink) Old 11-25-2013, 06:22 PM
Perfect. Thanks guys.
2013 Silverado HD:
Black 4x4 Crew LTZ
Jaxter is offline
post #10 of 46 (permalink) Old 12-04-2013, 08:16 AM
batwing's Avatar
I have EFI live from Kory, will the dealer be able to lower pressure with out screwing something up?
Ron
batwing is offline
