Sponsored by Discount Tire
Old 11-11-2007, 08:43 PM   eBay Motors   #1 (permalink)
06max
tires
I have an 06 2500hd stock height now and want to run 305/70r16 but would like to know if they will fit with a leveling kit installed or will I need a 4 inch lift. With a leveling kit only would a 285/75r16 fit and do I need a special tool take the torsion bars loose if I level it?
06max is offline   Reply With Quote
Old 11-11-2007, 10:06 PM   eBay Motors   #2 (permalink)
Maverick684
Factory Trans Pimp
Maverick684's Avatar
The 305's should fit just fine with a leveling kit on the stock rims, you may have to just barely trim a little bit of the fender to prevent the tires rubbing at full lock. Also, there is a special tool to remove the torsion bar keys Leveling kit, Lift Kit, Suspension,MAXX, Leveling Kits,Helper Springs for Chevy, Z71, Dodge, Ram, Ford, F150, Toyota, Truck, 4x4
John
05' Dmax LLY CC SB, 6in. lift
Some engine goodies
06' Pontiac GTO 6.0L
Maverick684 is offline   Reply With Quote
Old 11-12-2007, 12:25 AM   eBay Motors   #3 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
I have 285s on 16x8 rims and no lift in the front. I only have a very minor rub when at full lock and going over a bump. If you use stock wheels, they work even better seeing that they don't push the tires out past the fenders like mine are now. I did however use a few zipties to tie back the fenderliner on the driver's side. Each truck is slightly different though.
Old 11-12-2007, 06:43 AM   eBay Motors   #4 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
you can fit 305's on a GM truck but you need wider wheels then the stock 7" wheels so i would highly recommend just staying with the 285's and all you need to turn the T/Bars up is a 3/4" socket and find the torsion keys under the truck and give them both roughly 3 turns..if you want something a little taller then the 285's but not as wide as the 305's go with the 295-75R16..
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 11-13-2007, 04:51 PM   eBay Motors   #5 (permalink)
acarrpenter
acarrpenter's Avatar
I agree if you run bigger than 285's you really need a wider wheel. some people i know run 305's with just cranking the t bars. no problems if you have a gmc and it rubs you can remove the plastic piece between the grill and bumper and raise the bumper for a little more room and it looks good
06 chevy lly crew cab 4x4 s/b
3" keys up front 1" block in rear
20x10 Moto Metal 955
305 terra grapplers
4" silverline turbo back exhuast
Edge juice with attitude hot unlocked
intake modified
resonator blocked
access literider roll up tonneau cover
acarrpenter is offline   Reply With Quote
Old 01-19-2009, 12:48 PM   eBay Motors   #6 (permalink)
bob35012
bob35012's Avatar
anyone know if 285/75R16 will fit 03 stock suberban
bob35012 is offline   Reply With Quote
Old 01-19-2009, 12:53 PM   eBay Motors   #7 (permalink)
n0useforaname
Knows your Mom
n0useforaname's Avatar
Most people who are all stock need to crank the T bars and do trimming. So on a suburban..which has less of a lift....I would say you would have to mod it quite a bit. I might be wrong, but I know a 2500 is quite a bit higher than a stock 1500 or suburban..
LIFT: Ready Lift Leveling Kit
Old 01-19-2009, 01:42 PM   eBay Motors   #8 (permalink)
millerracing118
I have a 06 as well and i had 285s on it with the stock wheels, it fit just fine i turned the torsion bars up to level the truck, I have a 6 in lift on it now with 35s
millerracing118 is offline   Reply With Quote
Old 01-19-2009, 01:44 PM   eBay Motors   #9 (permalink)
bob35012
bob35012's Avatar
Talking
thats what i thought but i wasdid not know for sure and was hopeing somebody would tell me they woul fit withought any mods
Old 01-19-2009, 01:45 PM   eBay Motors   #10 (permalink)
bob35012
bob35012's Avatar
by the way is that an 06 sub 1500
