Dually Tire Size Difference - Chevy and GMC Duramax Diesel Forum
Sponsored by:
Old 11-17-2009, 05:47 PM   eBay Motors  #1 (permalink)
FLWanderer's Avatar
Was wondering if stock tires, door placard, (LT215/85x16) verses what a dealer put on my 06.... TOYO (LT235/85x16) requires a small, say, 1/2" spacer? I figure if I haul the 5th wheel those tires will get awlfully close due to the weight.
Any input would be appreciated.....thanks in advance.
06 Chevy Silverado 3500/LBZ
Duramax/Allison 6 Speed/EGR Blocker/Diablosport Predator
CrewCab Dually LT3 4x4
FLWanderer is offline   Reply With Quote
Old 11-18-2009, 06:04 AM   eBay Motors  #2 (permalink)
Diesel Addict
the LT235-85R16 depending on brand does need a small spacer between the duals so they dont rub but MOST wont! the 235s look way better IMO!
Project, Rogue Budget(Workstock Puller)
2006 GMC 2500HD, Stock Motor, EFILive by me, Billet 63 VVT, Motorsport Stroker CP3, 20% Nzls, ProFab Manis n Uppipes, BD IC, Hot Pipe IC, ProFab Y-Bridge, lots of other goodies
Old 11-22-2009, 08:20 PM   eBay Motors  #3 (permalink)
FLWanderer's Avatar
Thanks for the info....just for clarification...the tires are TOYO also. I have noticed that the 235's are just touching, so I figured with a 5'er on its back...they will touch. So the 1/2" spacer was thought of........hopes thats enough. hi hi
Thanks again...
Old 11-22-2009, 08:28 PM   eBay Motors  #4 (permalink)
duramaxchris06's Avatar
i would think that a 1/2 inch spacer will work fine for 235's. i have 265-75-r16 on my dually and run 2" spacers on the back
2006 Chevy LBZ 3500HD CC Dually LT3 4X4, 4" tb exhaust, 5 in ss tip, Shimed and egr blocked, PPE Hot+2, Autometer Cobalt, boost and pyro
Painted front bumper, bowtie emblem, tow mirrors, and fender flares, Cadillac style handles, Recon Fire and Ice light bar, smoked cab lights and 3rd brake light. NBS emblems
Diesel Performance Parts & Products | Alligator Performance.
duramaxchris06 is offline   Reply With Quote
Old 11-29-2009, 07:15 PM   eBay Motors  #5 (permalink)
FLWanderer's Avatar
I did put the 1/2" spacers on and notice there was some rubbing of tires. I was able to use the 1/2" spacer with about 8 threads getting a good bite on the stud. From what I understand, that should be ample. Again thanks for the info and help.
Old 11-29-2009, 07:29 PM   eBay Motors  #6 (permalink)
bigbluecow's Avatar
does anyone have any pics? I'm trying to decide on what to run on my dually.
Jason $
2003 3500 Dually LB7
MBRP 5" turbo back exhaust, PPE Economy, PPE boost valve, airbox mod, Flux Capacitor
2008 Pontiac G8 GT
Stock
Proudly serving in United States Army
bigbluecow is offline   Reply With Quote
Old 11-30-2009, 08:04 AM   eBay Motors  #7 (permalink)
bullwhipjkg's Avatar
i have the 235's with 1/4 spacer and no problems they look better then the 215's but i think the 265's with 2" gonna look lot better
06 3500 lbz crew dually sold back to finance company
bullwhipjkg is offline   Reply With Quote
Old 12-02-2009, 11:45 AM   eBay Motors  #8 (permalink)
FLWanderer's Avatar
Picture of 1/2" spacer between rear Toyo LT235/85x16's
Old 12-04-2009, 06:34 AM   eBay Motors  #9 (permalink)
Rode the Short Bus
Tigger's Avatar
Location: I'm a Wanderer! Freezing my ass in North Dakota
Spacer Required?
TyreBoyz, what is the best way to determine if the spacer is required. When I bought new tires I went to the 235-85R16 as well, but I don't know if they used a spacer. Can I measure between the tires when empty and tires at normal pressure and look for a minimum distance?
Thanks for the help.
Steven
Black Beauty - 2008 GMC CC Dually 4x4 black on black
I painted the grill, it added 20 hp, color matched is faster!
Member #4, #1 Irrelevant Member of the Exclusive GM DRW Club
Get your shit here! www.trollperformance.com
Originally Posted by Tigger View Post
The truth about asses is they don't change, they just get bigger!
Tigger is offline   Reply With Quote
Old 12-04-2009, 07:39 AM   eBay Motors  #10 (permalink)
Diesel Addict
you can see if the tires rubbed against each other,if they did or do you'll need to do spacers! have you ever seen what a tire looks like after its been curbed? well it wont be that bad but it will have similar scuff marks on the sidewalls!
