front wheels stick out - Chevy and GMC Duramax Diesel Forum
Sponsored by:
post #1 of 11 (permalink) Old 06-18-2010, 08:55 AM Thread Starter
I have a 2005 chevy 2500hd, it has a 6" lift and i currently run 35X12.5X20 on it. the front wheels stick out almost 3" past the fender wells, but the back one dont at all. anyone know why? the rims are rockstar XD and the rubber is toyo open country m/t
2005 2500HD EXTENDED CAB
6" LIFT 35X12.5X20 TOYO OPEN COUNTRY MT'S
20" ROCKSTAR WHEELS
4" EXHAUST WITH 5" TIP
K&N COLD AIR INTAKE
INTIMIDATOR PROGRAMMER BY BD DIESEL
7" FLIP UP SCREEN WITH NAV
jacked_max05 is offline
post #2 of 11 (permalink) Old 06-18-2010, 09:00 AM
68bowtie's Avatar
I cant explain it technically because I have never had a lifted truck but it is a very common issue on with all different lifts. Most guys I have seen on here to correct it will run wheel spacers on the back to match the front and add a deeper style fender flare. Some guys just don't trust wheel spacers. Hope that helps.
2008 Chevy 2500 Z71 CCSB LTZ- EFI-IDAHOROB, 5" Straight Pipe, Zone 3.5" adventure kit, Edge Insight CTS, Transgo Jr., Alligator trans lines
Waiting for install- EGR blocker plate
68bowtie is offline
post #3 of 11 (permalink) Old 06-18-2010, 09:11 AM
saw what you did there
theunderlord's Avatar
Its the brand of lift.
Some brands increase the front trac width tremendously.
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #4 of 11 (permalink) Old 06-18-2010, 09:16 AM
BurntOrngeLonghorn84's Avatar
I believe the front has to do with the independent front suspension...since you're moving all the steering geometry down, it widens out.
I also think lift manufactures do it to keep the stability in check as it corrects your center of gravity.
2005 EC/SB 4x4 LLY - purchased 06/15/09
- Ranch Hand Grill Guard
- 265/75/R16 Tires
- LBZ Mouthpiece Mod
- Bully Side Truck bed steps
BurntOrngeLonghorn84 is offline
post #5 of 11 (permalink) Old 06-18-2010, 09:17 AM Thread Starter
I have a 6" rdx lift. do you know if there is any way to fix that?
20" ROCKSTAR WHEELS
K&N COLD AIR INTAKE
post #6 of 11 (permalink) Old 06-18-2010, 09:18 AM
Get rear wheel spacers to match the front.
or.
Get a new lift.
post #7 of 11 (permalink) Old 06-18-2010, 10:04 AM
derrplyr's Avatar
well u could have gotten very positive offset wheels but u already bought wheels
2004.5 gmc sierra ext. cab short bed 2500hd duramax 6.6 LLY - SOLD
2013 VW Golf Tdi - bone stock - 40.5 average mpg
derrplyr is offline
post #8 of 11 (permalink) Old 06-18-2010, 11:23 AM
3/4 Tons from the factory have a wider track in the front than the rear. It just becomes more noticable with set of aftermarket wheels. Some lifts make them stick further out than others too.
2008 GMC SLT 2500HD DMAX White Crew Cab Z71 Line-X Bedliner, 17"x10" Ultra Predator 8 wheels, 305/65/17 BFG All Terrains.
SandgnatHD is offline
post #9 of 11 (permalink) Old 06-18-2010, 11:36 AM
my truck is just leveled and the fronts stick out 2 1/4 " (including side walls) and the rears
about 3/4 ".(including side walls)
03 LT CCSB Black
EFI by RidgeRunnerDiesel, TheBigDipper Injectors (35%), Airdog 165, Banks BIGHEAD,BatMo wheel, Profab Performance Headers, Up-Pipes, Down Pipe, 5" magna flow exhaust, (muffler delete), KN Air Cleaner, Trans by TheBigDipper, MikeL. Cooler, Autometer Boost and Exhaust Gauges, Leveled w/Rear Airbags, Hawk Brakes w/Powerstop C/D Rotors, Sleeves and Braces, 35x13.50x20 ATZ's on BMF NOVAKANES
35x12.50x16 INTERCO TRUXUS
07 LT2 CCSB C/B LBZ white
EFI Live , PVC reroute , EGR delete , 4" exhaust
305/70/16 on Centerlines w/ATZ's , 285/75/16 on stock wheels w/SST's
03hdcrew is offline
post #10 of 11 (permalink) Old 06-18-2010, 11:45 AM
trevorb_06's Avatar
Send a message via MSN to trevorb_06
Certain lifts will do that especially Fabtechs. It has to do with the new knuckles they use
http://www.facebook.com/home.php#!/p...?id=1370314361
Truck: 2011 Chevy Silverado 2500HD Duramax CC/SB | N-fab 6 step bars with 2" sectioned out of the front| Bushwacker Cut-Out Flares | Sulastic Shackles | Cognito 4-6" lift | Fuel Throttle 20x10 -12mm offset | 325/60R20 Goodyear Wrangler Duratracs | H&S Mini Maxx | DPF Delete | Urea Delete | EGR Delete| PPE Manifolds and Up-Pipes | Diamondeye 3" Downpipe | 5" Flo~Pro Exhaust w/Muffler
Coming soon: S&B Intake and FASS Lift Pump
trevorb_06 is offline
