Bf Goodrich tire pressure setting - Chevy and GMC Duramax Diesel Forum
Sponsored by:
post #1 of 8 (permalink) Old 10-23-2010, 06:04 PM Thread Starter
Hello can you tell me what the best PSI for a LT265/75R16 All Terrain tire with a load range of E it is mounted on a 03 2500HD 4*4 d-max Crew cab sb. They are at 60 PSI right now.
Thanks.
2003 GMC Duramax 2500 HD 4*4
K and N drop in Filter
Full 4 inch Flo Pro Exhaust System
Autometer A-pillar Dual Gauge Mount
Autometer Boost Gauge
Autometer Pyrometer Gauge
Pro fab Intake elbow
Alumina 6000k High beam system
Painless Relay Low's stay on with the High beam's
BFG All Terain tires LT265/75R16
2007st1300abs is offline
post #2 of 8 (permalink) Old 10-23-2010, 06:21 PM
Vrabel's Avatar
what it says in the door jamb. I run 50 all around myself.
R.I.P.
2001 Chevy CC/SB 4WD EFI Live DSP 5, LBZ Short Block, Cut LB7 Pistons,keyed crank and cam, balanced,LBZ Intake Runners with RDL Shorty Y-Bridge, EPR Twins, Big Dipper 40% overs, MBRP Cool Duals, LBZ CP3, ADII, BD Manifold, C2 Gauges, H2 Wheels, Cognito Sleeves and Braces, Hids-Hi-Low-Fogs.
Sheet Metal Workers Local #22
If it's not made in America, YOU paid too much!
Creatures of The Night Performance and ProFab Performance
Vrabel is offline
post #3 of 8 (permalink) Old 10-23-2010, 06:21 PM
Slave to the Interwebs
Johnasara's Avatar
Read the side of the tire it tells you max pressure. I would leave them at 60 to keep the ride softer. If you hook up to tow then go to the recomended. I leave mine around 50-55 psi running around town but if I tow or go on a road trip I inflate them to the recomended pressure
Johnasara is offline
post #4 of 8 (permalink) Old 10-23-2010, 06:58 PM
07-Dmax's Avatar
you cant use the door jamb for your tire pressure after you replace them with something aftermarket. no longer applies. look at your tire sidewall and see what it tells ya. I run 52lbs or so in my bfg AT tires, didnt want to run em at full pressure unless haulin as I was starting to wear out the middle of the tire. No less than 50 though with the bfg I would think. I am right at the edge of setting off my tire monitor system all the time.
2007 chev 3/4 ton ccsb ltz
6" rcd lift, amp research elec steps, mag hitec diff cover, amsoil dual bypass oil filter, bushwacker flares, 295/70/17 toyo m/t, a bunch of go-fast parts I cant name for the time being.
You didnt see me
you cant prove it
I didnt do it
07-Dmax is offline
post #5 of 8 (permalink) Old 10-23-2010, 07:59 PM
whiteknight2002's Avatar
???????? 60 psi for a softer ride?!?!?! Wow! The higher the psi the harder the tire is making the ride harder. My Michelin LTX can be maxed out at 80psi. I do run what the truck says in the door which is 60 all around. Personally I like 55 psi better because I do notice a small difference. But lets be honest.... If you are driving a Duramax you got it for power.... not the ride. So really its all up in the air and for yourself to choose what psi is best for you. But please never overload the psi... your only asking for troubles. :booboo
2002 LB7 2500HD LT 4X4
"America is all about speed. Hot, nasty, badass speed." -Eleanor Roosevelt, 1936
whiteknight2002 is offline
post #6 of 8 (permalink) Old 10-23-2010, 08:06 PM
Thanks.
And you are totally perfect at what you are at. Even if you were towing a light load.
post #7 of 8 (permalink) Old 10-23-2010, 08:15 PM
Trevor's Avatar
I run mine at 50psi. BFG KM2's
08 lmm cc/sb
built trans atp efi
Trevor is offline
post #8 of 8 (permalink) Old 10-24-2010, 06:19 AM
Johnasara's Avatar
60psi rides alot softer than the 80 most E rated tires call for.I stay around 50-55 and can still tow 4-5k without issues.
