Sponsored by Discount Tire
Old 07-08-2008, 10:11 AM   eBay Motors   #1 (permalink)
deuced
BFG 285/55/20 tires for towing?
Hi I have these tires on a 2005 LLY 2500hd c/c. The wheels are 20x9.5 and rated for 3400lbs. These tires are rated for 2835lbs per tire. I am looking at a 5th with a pin weight of 2300 lbs and a dry weight of 11000 lbs. My question is are these tires adequate or dangerous? Thanks alot.
deuced is offline   Reply With Quote
Old 07-08-2008, 10:30 AM   eBay Motors   #2 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
the stock tires on a Duramax are rated at 3040lbs each so you are loosing a few pounds in load index,also what ply tire are the 285's?
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 07-08-2008, 01:29 PM   eBay Motors   #3 (permalink)
deuced
Thanks for the reply. The tire says: Tread 3 plies Polyester, 2 plies steel and 1 ply nylon. Sidewall is 3 plies TriGuard Polyester. Load Range D, 2835lbs at 65 psi.
Old 07-08-2008, 02:15 PM   eBay Motors   #4 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
you'll be fine with LR D(8PLY)tires..i have done quite a few tires in my lifetime as shorts as it been and i have never had a problem with running a LR D on a 3/4 ton Diesel.
James
Business Truck
DD/Beat Around
Economy Saver
Old 07-09-2008, 12:05 AM   eBay Motors   #5 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Do what ever TYREBOYZ_DEMAXIN says! He's THE MAN when it comes to tires!
Jason
Old 07-09-2008, 12:17 AM   eBay Motors   #6 (permalink)
deuced
Awesome thanks for your help! So do you think a 2500hd with my airbags and these tires hitching up to a 2400 pin weight toy hauler is good still? I know I am probably over at the scale by a bit, but I don't want tire failure. Thanks again
Old 07-09-2008, 04:50 AM   eBay Motors   #7 (permalink)
01Dmax
01Dmax's Avatar
What he said. I dropped from load range E to load range D when I got my BFG's, mainly to have a little more compliant tire, as I dont have my truck loaded up all the time. Even when the time does come around that I need to put some weight on it, the tires are more than adequate assuming you check the pressure, and are not running a retarded load on them.
2001 Club Cab 2500HD 4x4 D/A
EFI Live, Cobalt Pyro, PPE boost valve, PPE lift pump, Grille guard, Moon visor, Leveling kit, 285-75-16 A/T TA's, Grand Rock stacks, spray in bed liner
1993 Z28 M6
Lloyd Elliot ported heads and intake, LE 1.6 cam, 1.6 RR, 52MM BBK TB, 30lb/hr injectors, PCMforless tune, K&N FIPK, Pacesetter longtubes, Pacesetter ORY, Magnaflow catback -the cat Dynaspark billet optispark, RAM kevlar clutch, 275-45-17 pirellis on 17x9.5 ZR1's up front, 315-35-17 on 17x11 ZR1 rears
01Dmax is offline   Reply With Quote
Old 07-09-2008, 05:59 AM   eBay Motors   #8 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
yes you'll be fine with that load....i run a LR D 285-75R16 on my LBZ and had a load behind me that scaled just a tadd over 30,000lbs gross weight and it handled it like a champ..
to give you an idea the back tires are rated for 5070lbs and if you have a 2400lb pin you still have a 2670lbs worth of tire left over..
James
Business Truck
DD/Beat Around
Economy Saver
Old 07-09-2008, 07:18 AM   eBay Motors   #9 (permalink)
deuced
Thanks, I appreciate it that makes sense. Does the weight of the truck add to that 2400lb pin weight. For example if the rear axle weight is 3000lbs am I 5400lbs on the tires? Sorry for all the questions, I'm just out of my realm on the tire scene.
Old 07-09-2008, 12:27 PM   eBay Motors   #10 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
your truck weighs roughly 7200-7400lbs depending on the package that came with the truck but to be honest i'm not sure how much the backend weighs,i'm sure it doesn't weigh even close to 3,000lbs..
James
Business Truck
DD/Beat Around
Economy Saver
