all the classic with 16" wheels come in a 6.5" wide and it is only with to wide a tire this will happen,it took us almost 2YRs to figure out what cause this and yes after it go's long enough it will wear the wheel bead to nothing and then what happens it will cut into the tire bead causing leaks and blowouts and yes i have seen it that bad that they blow so i thought i would warn you all of this so don't put 285's on your stock Alluminum wheels or else plan on doing wider wheels allthough 265's don't do that.285's equal like 7.5-8.0 wide wheels
heres a few pics of one with 1 set of 285-75R16 tires and roughly 1 half years time later this is how they looked today when i changed out the tires
there were some serious outside factors there, i would say overinflation, heavy pulling,and long distances.....plus obvious abuse,that much dirt packed up in the beads of oversized tires, and were they froze on? i see the hammer marks on the back side...this is however typical wear on big trucks when they are in the 800k - 1m mile area...what did the vehicle look like? were they all like that?curious ,thanks
obtw- you can service that wheel if you really wanted to....use a grinder stone on a buffer and grind the inner lip off with a up and away motion, then use a heavy wire wheel in the oppisite direction down and towards to pull the lip smooth.... but you can only do it once.... and i wouldn't do it to my own wheels
__________________ "06" LBZ 3500HD 4x4 Standard Cab
Allison Transmission
Bone Stock - 180k - and I drive it like I stole it.
ARE alum mods w/ 265/75R16 Firestone Transforce A/T 10ply
Redneck bedrails, B&W turn-over gooseneck hitch, some tint, a little bit of Lund black plastic, and Sylvania Silverstar Ultra's just to be annoying.
Open for suggestions on upgrades, was thinking about a Flashpack
these wheels were on a 00 2500HD RC LB equipped with the 6.0L Gas engine with 180,000 odd miles(going off my memory)and that was the 3rd set of 285's he had run and i do know that for a fact because we do all of his tires and no they come off quite easy without a sledge..
i have seen quite a few wheels like this and the only ones that are like this is on the 3/4T and 1T trucks with these wheels and wider tires then what the 6.5" wide wheels are recommended for.yes i believe having more PSI increases the wear but i wouldnt realy call it over inflation..
i never notised it on the 1/2tons so i would say load/weight and PSI play the biggest role in this.
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
i had 285s on my stock wheels with nitrogen and the centers of the tires are junk, only lasted 10,000 miles
__________________ Chase
LMM
EFI Live
Dpf and Egr Deleted
Trans Go Jr
You can get much farther with a kind word and a gun than you can with a kind word alone.
MPF ALL IN ONE LOGISTICS LLC
also if you dont have wide enough wheels for your tires it can and will cause premature tire wear..
Business Truck
DD/Beat Around
Economy Saver
Location: in between some fields of Parke County Indiana
wow, guess I better be gettin either wheels or tires then. it doesn't do this with 265's though?
__________________ 2002 2500HD Crew Cab Short Bed
4" MBRP Turbo Back
PPE Standard, PPE Boost valve, Optix Boost, Pyro, Trans temp
B&W TurnoverBall and tow mirrors self installed
Rhino'd bed, 285 ProComp EXtreme A/Ts & T-bars cranked
Banks RamAir and modded intake horn
Allison Deep Pan with MikeL cooler
(waiting on my injectors to come back )
i have noticed only slight wear with the 265's but only on tires with the bead gaurd,the extra rubber that covers the lip of the wheel and even then it is hardly noticable after 75,000miles.
Business Truck
DD/Beat Around
Economy Saver
Maybe it's time for GM to throw in proper wheels and $800 285/75r16 on my $35,000 truck.
I mean, seriously the stock tires are a joke. I used to have to got in 4wd if I was going up the slightest hill on grass. That is NOT cool when you have the local "big ass diesel"
