Disclaimer: I have searched the threads, and had no luck finding someone with this rim and a 4-6 lift. Sorry if it has been posted already.
Have seen these rims on levelled trucks within the forum, but not lifted, and not with these tires. Wanted to know if they will clear the spindle and UCA, stock or aftermarket- planning on running a Cognito 4-6 set on 4 or just higher if absolutely necessary. Shouldn't need aftermarket UCA's for correct ball joint angle, but might need them to clear rims and tires. Very stuck on these rims and tires, and this offset as I drive on gravel and enjoy nice paint. Want to go with a lift for the ride and proper suspension geometry. Would look at a CST 3-6 STL as well. So my questions are:
Will rims with this much back spacing and this size tire work with a Cognito 4-6?
If so will I need there UCA's?
Also which shock, deavers, and air bag kits combos are guys most happy with? Really want a good ride.
Truck is a 2017 2500
Thanks
Thanks
