need to order tires for the shop truck. we are going with Nitto Dura Grapplers but im not sure which size to go with?
its a 2005 crew cab dullie 2WD.
i was thinking as big as possable so as to try and lowwer rpms at high way speed as it still has a 5 speed in it?
__________________ Vehicle 2008 Chevy Crew Cab Short Bed Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck Drivetrain LMM Duramax, Allsion 1000 Transmssion Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
I have 265's on my 01 and don't have any problems with towing a 12000 lb 5th wheel. My friend says that he has problems with 265's rubbing each other but he is pulling a 15000 lb gooseneck loaded cattle trailer. I guess it depends how much tongue weight or load you will have.
Plus you will have a little less pulling power with the smaller original tires.
well we roll with the truck maxed out everywhere we go so that kinda has me worried
i hate metric! how much bigger (taller) are 235/85/16 vs the 215/85/16 that came on it? and they don't make the Dura Grapplers in those sizes so what is a good all sesion high way tire that lasts a long time and is quitet?
Continental for durabilty and qiuetness...
__________________ Currently owned vehicles: 1993 BMW E32 750iAL
1995 BMW E36 325i
1998 BMW E38 740iAL
2002 BMW E39 M5
2005 BMW E60 530d MAPPED (320hp)
2006 Chevrolet Silverado LLY Duramax Diesel Mods on the Dmax (RED=upcoming): Straight Pipe EFI Live
Stage 4 Suncoast
The 215s are 30.4 inches and the 235s are 31.7 inches. If your wanting a good hwy tire then go with Michelin LTX M/S. They are pricey, but you will get the most miles out of them. They do good in the rain and snow but you will get hung up in wet grass with them.
__________________ KYLE
2010 Camaro SS LS3 426 HP
Plus you will have a little less pulling power than with the smaller original tires. ( I'm sure that's what you meant Rob. )
If you're loading to the max and/or hauling heavy, lower rpms with bigger tires does not always equate to better mileage.
I need performance in tires over longevity, so I run the Revos and they DO perform. Very well made, low weights needed to balance, they’re a 50k mile tire and I guess that's about right but, I don't run the tread down like most people. I can't gamble in the traffic conditions that we must travel here.
