Sponsored by Discount Tire
Old 08-18-2008, 03:53 PM   eBay Motors   #1 (permalink)
Methu969
Tires rubbing
I just got an 06 and it has 33" tires, I am getting some rubbing on turns. The truck is level but no signs of a leveling kit on the front. What are my options other than a lift? Some of the wheel well was cut out to stop rubbing but still rubs.
2006 Duramax LT (LBZ)
Allison tranny
PPE Programmer
EGR blocker plate
4" MBRP Turbo Back Exhaust
S&B COld Air Intake
315/70/17 BFGs
6" RCD lift
One day, long, long ago, there lived a woman who did not whine, nag, or bitch. But it was a long time ago, AND it was just that one day. The End
Methu969 is offline   Reply With Quote
Old 08-18-2008, 04:13 PM   eBay Motors   #2 (permalink)
04LB7DmaX
04LB7DmaX's Avatar
Id say trim a little more off if possible, or just crank the torsions a full turn or two. They also sell torsion key lifts, which give you about 2" more lift in the front.
-2004 LB7, Ext. Cab S/B, LT
-6" Tough Country Suspension Lift
-35" Toyo Open Country M/T
-18x9 KMC XD MONSTERS (Black)
-PPE Standard Xcelerator
-Auto Meter Cobalt Gauges Pyro/Boost
-AEM Brute Force Air Intake
-MBRP 4" Straight Pipe Exhaust w/ MBRP 5" Black Tip
-Buckstop Front/Rear Bumpers
-N-Fab Side Steps
-ProTech Headache Rack (Line-X'd)
04LB7DmaX is offline   Reply With Quote
Old 08-19-2008, 12:17 AM   eBay Motors   #3 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Ya triming the fender wells and cranking the torsion bars are about it. But, if your truck is level then the bars might not be able to be raised! I had to run zip ties through the inner fenders on my truck and tie them off to pull them back a little. I also have seen people use a heat gun and form the plastic a little.
What exactly is it rubbing on?
Jason
Old 08-19-2008, 10:38 AM   eBay Motors   #4 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
also what size tires do you have other then 33's?
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 08-19-2008, 05:13 PM   eBay Motors   #5 (permalink)
Methu969
My tires are 315/75/17 BF Goodies. I will look into the torsion bars.
Allison tranny
PPE Programmer
EGR blocker plate
S&B COld Air Intake
315/70/17 BFGs
6" RCD lift
Old 08-19-2008, 05:31 PM   eBay Motors   #6 (permalink)
OneBadDmax
OneBadDmax's Avatar
I believe 315's are considered 35's. I have 285's and even though they dont meaure it, they are considered 33's.. I had very little rub with the 285's, I had to trip a corner off of the front valance under the bumper
2006 Silverado Duramax
Ext. Cab Short Bed.
MBRP 4" T/B SS
PPE
Autometer Cobalt boost and Pyro
Hummer wheels with 285/70/17 Nitto Terra Grapplers
Whelen amber strobes on back rack with amber strobes in the grille.
Back Rack
Boss Plow
OneBadDmax is offline   Reply With Quote
Old 08-19-2008, 07:09 PM   eBay Motors   #7 (permalink)
aggar
Smoke. It's what's cookin
aggar's Avatar
I've got 315's on H2's and they rub. Crank the bars and trim the plastic valance and some other parts where it rubs.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058, SC Case Brace, 68mm Cheetah, EFI Live, Air Dog 150 II, Auto meter gauges and pod, EGR Blocker and FRPV shim kit, ATS dual CP3 kit, 60% Extrude hone injectors E-locker
Old 08-19-2008, 07:38 PM   eBay Motors   #8 (permalink)
Methu969
Rubbing Tires
Ok here are a few pics, you can see the well cover is cut back and it is rubbing on the right side well. OK dumb question, how do I check the torsion bars or adjust them??????
Allison tranny
PPE Programmer
EGR blocker plate
S&B COld Air Intake
315/70/17 BFGs
6" RCD lift
Old 08-20-2008, 12:19 AM   eBay Motors   #9 (permalink)
04LB7DmaX
04LB7DmaX's Avatar
You should take a mallet to the metal and smash it back some, then spray it with rust-o, and to check the torsions there will be a cross member with 2 bolts hanging down,cant miss it, directly underneath the two front doors, if you tighten them 2 full cranks you should gain probably about 1" more clearance, is your truck not lifted and your running 35s?
-N-Fab Side Steps
Old 08-20-2008, 12:34 AM   eBay Motors   #10 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Hmm from the looks of that your truck HAS to have a lift of some sort on it. I doubt cranking the torsion bars will make a difference. Can you tell where there rubbing at? Another problem you have is the wheels on your truck have a pretty good offset causing the tire to stick out further and will rub easiar. Might have to do what 04LB7DmaX suggested and beat the sheet metal in a little.
Do you have pics of the whole truck?
Jason
