Sponsored by Discount Tire
Old 08-25-2008, 08:52 PM   eBay Motors   #1 (permalink)
catman_05
Exclamation Balancing Wheels Issues
Hey Guys I Bought A Brand New Set Of 18/9 Rockstars, With 305/60/18 Bfg Km2s. I Have The Place Were I Got Them Balnce Them Twice Now And They Still Have A Pretty Good Wobble At Like 45 And 65. They Are Using Stick On Wights And The Machine They Are Using Is A Fairly New Hunter Machine. Has Anyone Ever Had A Problem Like This . The Second Time They Balanced Them Today They Were All Off And I Watched Him Balance Them To 0 Just Like He Did Before. They Only Have Like 200 Miles On Them.
2001 CHEVY, CC,SB, 4X4. EFI LIVE TUNED BY BRAYDEN, CHEETAH STAGE 2, FASS 150, SUNCOAST STAGE 3 BY FLEECE, 5 INCH MBRP, AND AFE STAGE 2.
catman_05 is offline   Reply With Quote
Old 08-25-2008, 10:16 PM   eBay Motors   #2 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Most of the time the tire is what makes it go out of balance. Did they try rotating the tires? Do you feel it in the steering wheel or in the seat? There are 2 different ways to balance a tire. One way balances the tire for it being ovaled in shape the other way balances the tire for it being moving side to side. Usually the side to side one helps the most. I balance tire but I dont use sticky weights. I think they balance it for being ovaled out. The only way to balance it side to side is to put weights on the inside and outside of the wheel.
The only thing Id recommend would be there is a bag of powder they can put in a tire (usually is for larger truck tires though) you might want to ask them to try that.
You could very well of had a defective tire. If that cant help it you might want to talk to the tire place about getting another set of the same tires or a different tire.
Jason
Old 08-25-2008, 10:24 PM   eBay Motors   #3 (permalink)
catman_05
I Feel It In The Wheel And My Leg By The Door, No They Didnt Rotate Them, But They Did Twist Off 3 Lugs On One Wheel!!! So I Need Ta Fix That It Will Probably Be A Pain In The A##
Old 08-25-2008, 10:33 PM   eBay Motors   #4 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Wait what?! They didnt fix it for you?
There could be another problem. We just had a car come into the shop that we put new wheels on. The customer had it for a week said it felt like one of the tire was falling off. So we put the car up in the air and he was right! The wheel was falling off then when we took it off 3 of the 5 studs broke and another one was stripped. One of out more experianced techs did it so it definatly didnt leave loose. We started to check the other wheels and had 2-3 studs on each corner break. Here when the rim went on you had to align the wheel on the studs. If you just put the tire on and put the lugs on with a impact gun the wheel went on offset like it fell down on the studd instead of centering the stud.
You could try taking the wheel off then put 2 lug nuts on and make sure the wheel goes on straight. Also try rotating them. If you feel it in the wheel the front or front left tire could be out. It migth straighten itself out if you put it in the front. Id do the 2 lug nuts to all of them if you had a problem with studs breaking.
Jason
Old 08-26-2008, 10:12 AM   eBay Motors   #5 (permalink)
catman_05
Tow Master What Do You Mean By The 2 Lug Nutz
Old 08-26-2008, 10:19 AM   eBay Motors   #6 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
i think what he is saying is put 2 nuts on at a time across from each other to make sure the wheel centers properly on the hub..
rotate the tires and see if the vibration changes any,if it does you have a out of round tire..the Hunter Balancers are some of the best balancers avalible and thats what we use.
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 08-26-2008, 12:03 PM   eBay Motors   #7 (permalink)
05 3500 2wd
05 3500 2wd's Avatar
Tire Balance
Check out this place
Tire Balancing Products
I just ordered from them. I like the look of the ceramic beads in place of the powders. I have not got them installed yet but the stuff on the site looks good. They are real friendly and informative. I did have a slight order problem and they are sending me the correct stuff and a call cat to send the stuff back. I pay no shipping to correct it (nice customer service). A local cycle shop has put them in 2 bikes and has not received any feedback on them yet. I told him if they did not work he would have herd about it by now.
Clifford is a 2005 GMC Loaded SLT 2wd with; Killer Bee true cold air intake and ported LBZ intake overhaul kit, AFE Inter cooler pipe, Diamond Eye down pipe, BD drivers side manifold, Silverline 4" S/S straight piped exhaust, EGR Blocked, PPE On level 2, Bully Dog pillar mounted outlook monitor, 19.5" aluminum wheels with factory lug covers, Goodyear G647RSS 225/70/19.5, BFXenon 6000k Headlights Low & Hi, Rear mounted under the bumper halogen lights, EX down Tailgate assist, Put co S/S mud flaps, Put co Racer front grill cover, compete interior wood dash kit, Dual Liner 3 piece bed liner with rubber floor mat, Roll-N-Lock tonne cover with tail gate lock, and AVS in channel vent visors.
05 3500 2wd is offline   Reply With Quote
Old 08-26-2008, 01:16 PM   eBay Motors   #8 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
one more thing that I have experinced in the past along with what they have said, I have had times where a lot of water got into the tire during inflation and would not let the tire balance properly, if that shop has not drained the air compressor lately this can happen...
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
Old 08-26-2008, 02:09 PM   eBay Motors   #9 (permalink)
jcline
jcline's Avatar
One thing I would have them try if they dont have it find somone who does . Have them "Roadforce" the tires its a machine that hunter sells. It goes back to the "you can balance an egg but you cant make it round" bit. What the will do is see how much force it takes to collapse sidewall, rim run-out, and so forth the it will match up lets say RF wheel with LR tire and also tell them where to index it to. We had one of these at the last Chev dealer I was at and it is awesome. Spendy though expext about $200 bucks or so to balance.
jcline is offline   Reply With Quote
Old 08-26-2008, 02:22 PM   eBay Motors   #10 (permalink)
Buck
Buck's Avatar
Make sure the little red or yellow dot that is on the sidewall is matched up to the valve stem. I don't remember what color BFG's are. That little dot is there for a reason. I have no idea what the reason is but I have fought wheels for an hour only to realize I forgot to line the dot up. And having them road force balanced is the best way to get them right. We tend to not use road force on big tires here because the nobbys on the big tires beat the machine up a lot. But if we can't get it right the old way we will do it.
Vehicle 2008 Chevy Crew Cab Short Bed
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline   Reply With Quote
