Sponsored by Discount Tire
Old 09-14-2008, 06:31 PM   eBay Motors   #1 (permalink)
timespentsearching
timespentsearching's Avatar
biggest tires in stock well?
what is the largest tires i can fit in the stock well? ill have my air level rite kit in and also air bags in the back so its more like a 2 inch kit but really same diff. this will be a extra set to play around. i got my 235/85/R16 tires and stock rims for towing and the such. either looking at a 16 or 17 inch rim. im thinking of maybe getting a set of stock rims and powder coating them. let me know thanks guys.
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 09-14-2008, 08:45 PM   eBay Motors   #2 (permalink)
timespentsearching
anyone? im relaly looking at diameter here more then width, id like to put 285 or 305 wide tires on it, mosty likely 285's
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 09-14-2008, 09:06 PM   eBay Motors   #3 (permalink)
gunmetalsi
gunmetalsi's Avatar
i'm wondering the same thing...i see a thread somewhere else but could not find it.
Bryan
03 GMC 2500HD LB7 4x4 CCSB 285/75/16 Hankook DynaPro on PYO 4" MBRP Cool Duals High Idle Switch Superchip Flashpaq Recon Line of Fire and Ice Recon Smoked LED 3rd Brake light Brite Box headlight mod High/Low and Fog Light
Toys-99 Civic Si-Turbo 490hp 11.820 @116 mph 1.797 60', 1995 Buell S2, 1988.5 Suzuki Samurai(wheeling rig someday)
www.myspace.com/firejunky99
gunmetalsi is offline   Reply With Quote
Old 09-14-2008, 10:31 PM   eBay Motors   #4 (permalink)
BigRedChevy
Super Moderator
BigRedChevy's Avatar
Without trimming a 265/75 R16 is the biggest, but with just a little triming the 285/75s will fit and i have herd of a few people running 305s, but it depends on the wheel offset.
KYLE
2010 Camaro SS LS3 426 HP
Old 09-14-2008, 10:53 PM   eBay Motors   #5 (permalink)
jcline
jcline's Avatar
I have 285/75/16 on stock rimes right now with Ready lift leveling keys which raised it about 1.5-2 inches. Next I will put 33x12.5x18 on it I have a friend who has identical truck with this set up and is running the 33's and it looks and stands and looks good with no rubbing.
2005 LLY CCSB
Leather, Bose, XM
Truxedo bed cover, Line-X
305/75/16 BFG M/T's Ready Lift Leveling kit
B&W Turn-over-ball
Resonator plugged
NO CAT!!!!
Superchips Flashpaq (It was free and now I know why what a P.O.S.)
BG Synthetic fluids throughout!
jcline is offline   Reply With Quote
Old 09-15-2008, 06:35 AM   eBay Motors   #6 (permalink)
timespentsearching
you got tobe able to fit bigger then just 285/75's. my 235/85 tires are way taller then the 75's (almost 32 inches when new) and they fit and have room to spare. i know the consern in turning though. i want to have a wider tires really (going to do some drags and pulls with it next summer) but also what the hieght. also these tires will get swtiched in and out. get way better milage with the 235/85 and they are better in rain and snow on the highway.
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 09-15-2008, 02:30 PM   eBay Motors   #7 (permalink)
Durallymax
I tucked 315/70R17s on my stock height truck. And took the tbars up only one turn.
Now It does rub the sway bar a little and the cab body panels. But taking the bars up more solved this. However I dont like that look.
I had to do some extensive trimming, zip tieing and banging to fit them.
These are on H2s like everybody else in the world and that ofset seems to be perfect.
Im now going to be running 265 Transforces as I have no reason for big expensive tires.
The "Last Minute Puller"
'03 GMC 2500HD LB7/Allison EC/SB 4x4
Suncoast, EFI Live, S400, Studs, Stock Motor
Badger Truck Pullers Association Member
Thanks to all of my sponsors
Durallymax is offline   Reply With Quote
Old 09-15-2008, 03:39 PM   eBay Motors   #8 (permalink)
aggar
Smoke. It's what's cookin
aggar's Avatar
I"m running 315's right now on H2's for pulling. A little rubbing but nothing too serious. I did do some trimming and need to cut some metal for pulling next year. But I generally run 295's or 285's with minimal to no rubbing. 285's are about the right size. If you go aftermarket rims they will more than likely tend to rub a little more. H2's have a better offset for bigger tires.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058, SC Case Brace, 68mm Cheetah, EFI Live, Air Dog 150 II, Auto meter gauges and pod, EGR Blocker and FRPV shim kit, ATS dual CP3 kit, 60% Extrude hone injectors E-locker
Old 09-15-2008, 04:00 PM   eBay Motors   #9 (permalink)
timespentsearching
im thinking a 285/75r16 or 285/70/r17 what do you think. what is the offset of the H2 rims? im thinking of maybe tring to get a set of alum chevy or GMC rims from anyone around that has upgraded and get them powdercoated. im sponsored my a powdercoating company so thats why, what do you think
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 09-15-2008, 04:23 PM   eBay Motors   #10 (permalink)
aggar
aggar's Avatar
I'd do it. I'd run the h2's personally. With the 285's they'd fit fine and with minimal rubbing and not have to worry about the narrow factory chevy aluminum wheel since the h2's are 17x8.5" and the Factory alums are 16x 6.5" But you jump up in price going to a 17" tire.
Tireboyz Demaxin had a thread on here about putting too wide of tire on the factory chevy wheel and the bead getting worn out and tires coming off. That's why i'm suggesting the h2's.
