Oil out of dipstick - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By SilverGorillaLML
post #1 of 6 (permalink) Old 11-16-2019, 10:52 AM Thread Starter
Oil out of dipstick
Bought truck earlier this year its a 2001 gmc 2500hd LB7. Few weeks after buying it started blowing heavy white smoke from the pcv vent. I put seafoam in the fuel filter and double dosed my fuel with howes and it went away.
A couple of months later i was hit with mystery limp had a new pump put in didnt solve the problem, continued to have hard starts while warm. Changed the oil and had 20L of oil so i assume an injector is leaking.
Today, a month after changing the oil i have noticed oil leaking back out of the pcv vent tube and when i removed the dipstick oil splashed rapidly out of the tube. This never happened last time i had the pcv vent problem.
Any suggestions? It is very cold outside, could this lead to a problem?
Thanks.
Monsiep is offline
post #2 of 6 (permalink) Old 11-16-2019, 02:50 PM
Could it be your injector(s) are so bad that your crank case is filled to the teats with fuel? Or the return lines?
I would assume that a 50/50 mix of fuel and oil in your crank case has wreaked havoc on the internals unfortunately. Oil analysis stat!
Sent from my google machine
"Stinky Pig"
2003 Sierra 2500 Crew 4x4–Charcoal Grey Metallic
325k kms and counting
LLY Head swap
LBZ full intake w/MP
Flo-Pro Downpipe
4" Straight pipe
EGR delete
PCV Re-route
EFI Live (E. Stock/30HP/60HP Tow/high idle/No start)
Edge CTS2 with EGT
AxysAssault is offline
post #3 of 6 (permalink) Old 11-16-2019, 11:28 PM
SilverGorillaLML's Avatar
Drip some oil off the dipstick onto a paper towel. It will form a halo if it has fuel in it. If it has major blow by out the dip stick or oil fill tube next step is a compression check.
407driver likes this.
Race/Pulling truck:2012 Cummins/Built 6.8L/Big air/Big fuel/48RE Swap/PCS 2000/B&M Gated shifter
Tow rig/DD 05 lly cclb loaded. Some goodies
post #4 of 6 (permalink) Old 11-17-2019, 03:21 PM
ALLY Cat's Avatar
Have you checked the PCV system? There should be a servicable PCV valve next to the alternator but I'm not real familiar with the gen 1 Duramaxes. IIRC there are PCV check valves on the valve covers also. If previous owner did a PCV reroute, there could be a clogged/pinched, ice block tube or plugged catch can. Worth taking a look....
ALLY Cat is online now
post #5 of 6 (permalink) Old 11-18-2019, 08:02 PM
I would say injectors, dont know what else would cause it to make oil unless the fuel return line is leaking.
2019 Expedition
2005 C6
2003 Silverado LB7
1948 Jeep
LS1POWERED is offline
post #6 of 6 (permalink) Old 11-18-2019, 10:54 PM
pretty good video on an injector return leak.
Rad24 is offline
