2004 2500hd Sierra - Chevy and GMC Duramax Diesel Forum
post #1 of 2 (permalink) Old 11-21-2019, 03:29 PM Thread Starter
2004 2500hd Sierra
I will drive about 3 miles then it feels like it falls out of gear and stall once it died and threw a code(p0700 I think it was) but haven’t got it since then. It will die if you don’t press the throttle down but it won’t throw a code. It has 220,000 miles. Replaced the filter head, batteries, and the cp3 sensor. What is wrong with it we need to get it to work please help thanks.
brmaRR is offline
post #2 of 2 (permalink) Old 11-22-2019, 06:20 AM
The P0700 is a generic code telling it to set the MIL, need a better scanner to read the other tranny codes that it should have also.
mray is offline
