No start no rail pressure - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 3 (permalink) Old 01-05-2020, 03:45 PM Thread Starter
Bought an 02’LB7 that Only started with fluid, guy said it just needed a new CP3. Got a new CP3 installed (I am mechanically inclined)it myself, double checked all my lines & fuel fittings made sure everything was good bled the hell out of it but still no start. No rail pressure On scanner. swapped out the fuel rail pressure regulator, blow Out all the lines, still not start. Did a rate return test and didn’t get any fuel, cracked the line to the fuel rail tee and 1&8 inj and got fuel and removed all the glow plugs and turn motor over see inj we’re stuck open but cylinders were dry. Looked through all prior post but didn’t see anything. Any help would be greatly appreciated.
Arcain08 is offline
post #2 of 3 (permalink) Old 01-05-2020, 08:02 PM
stevewaclo's Avatar
Location: Carson City, NV Proud Participant, Federal Witness Protection Program
Question A Mystery...
Hello and welcome to the Forum!
As you have learned, relying on advice from the PO can be risky, unless the CP3 was professionally diagnosed, in writing.
... cracked the line to the fuel rail tee and 1&8 inj and got fuel.
A visual indication of fuel at the points you noted above says nothing about fuel pressure there but If it is adequate, whatever pressure sensor that is talking to the FICM may be defective or a signal is not getting to the FICM because of a wiring problem.
As you probably know, the Fuel Injection Control Module (FICM) will not wake up and fire injectors until it is informed of around 5000# of rail pressure. Im not sure where the FICM gets that signal, but should be easy to learn.
Cant recall where you can tap an injector firing signal. Relatively high fire volts that drops down to hold volts I believe.
Or, all is well up to the FICM and injectors are not firing because it is defective. Good move on pulling glow plugs to check there. If GPs are still out, R&R of those inexpensive items would be a smart move.
Some things to consider and Im sure others will weigh in.
Keep us posted.
2003 GMC Sierra 2500HD SLE ExtCab CA Emissions; 155k; Allison 1000 w/Transynd X2 Flush & Fill; 8' bed; AFE/CAI; MBRP 4" Exhaust; Side Tint, 33% VLT, rear, Limo; Smittybilt Stainless Side Nerf Bars; Sprayed-in Bed Liner; MadJack Fuel Filter Access Door; Regular Used Oil Analysis (latest available on request), Blackstone Labs; EGT/Boost Gauges; Dual Chrome Dipsticks, JC Whitney; Stainless Steel fuel filter head bleeder screw; New WP and Hydroboost; Billet Aluminum Fuel Filter Housing Spacer; Professionally repaired instrument cluster (new steppers and lamps); Does anybody ever read this s%#t?; Injectors under warranty @ 70k; 2nd set DIY @ 155k
stevewaclo is offline
post #3 of 3 (permalink) Old 01-07-2020, 01:04 PM
Brent@LDS's Avatar
Where did the CP3 come from? Also might be high return rates on the injectors allowing the truck not to build fuel rail pressure.
DMAXfirefighter likes this.
Looking for LB7 Injectors?
Check these prices out!
......... Lincoln Diesel Specialties
Phone: 920-361-7700
Click here For,
LB7 Injector Install Instructions
