02 lb7 low actual rail pressure, any advice would be awesome! - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 01-11-2020, 06:30 PM Thread Starter
Jamieslb7's Avatar
Hey, I’m new to this forum but have found a ton of great info. I recently bought a 02 gmc 3500 and realized it has low fuel pressure it has trouble getting over 40 MPa at wide open throttle. I also noticed on my scan tool the commanded fuel pressure regulator was really high. I just need some advice if I should be budgeting for a new cp3 or fuel pressure regulator or both? My truck feels like Godzilla has ahold of the back bumper lol Thanks y’all for your time. I attached a screen shot was I was seeing on the scan tool.
File Type: jpg 3A7D16D3-F1B6-4AC9-B760-373FDE9BC477_1578792515381.jpg (21.6 KB, 50 views)
Jamieslb7 is offline
post #2 of 9 (permalink) Old 01-11-2020, 06:38 PM Thread Starter
Jamieslb7's Avatar
Sorry forgot to mention I put on a new air dog 100 and new k&n fuel filter along with new seals in the fuel head.
post #3 of 9 (permalink) Old 01-18-2020, 02:53 PM
stevewaclo's Avatar
Location: Carson City, NV Proud Participant, Federal Witness Protection Program
Try this
Hello and welcome!
A chronic problem with LB7 injectors is trouble with the ball and seat in the internal return circuit. One or more may become badly worn and instead of the typical return flow, diesel fuel is hydraulically “short circuited” and correct rail pressure cannot be established.
A simple test may be done by going under the truck and disconnecting the return fuel line between the fuel cooler and tank (often impossible due to corrosion, so cutting in is necessary) and measuring fuel return flow into a container with the FICM fuse pulled and 15 seconds of cranking.
The test may also be performed topside on a bank-by-bank basis, but I believe if total return is incorrect, just do all injectors at once.
Consider SAC vs VCO’s.
Search the forum for specifics and a better pic of injector innards.
Other issues may cause low rail pressure, but this is often low hanging fruit.
File Type: jpg 4D40D833-FD18-4469-A962-AFC2E7C5FB9D.jpg (21.1 KB, 28 views)
File Type: jpg F77963F3-51AF-474E-8A59-3AB352BBE640.jpg (21.4 KB, 28 views)
2003 GMC Sierra 2500HD SLE ExtCab CA Emissions; 155k; Allison 1000 w/Transynd X2 Flush & Fill; 8' bed; AFE/CAI; MBRP 4" Exhaust; Side Tint, 33% VLT, rear, Limo; Smittybilt Stainless Side Nerf Bars; Sprayed-in Bed Liner; MadJack Fuel Filter Access Door; Regular Used Oil Analysis (latest available on request), Blackstone Labs; EGT/Boost Gauges; Dual Chrome Dipsticks, JC Whitney; Stainless Steel fuel filter head bleeder screw; New WP and Hydroboost; Billet Aluminum Fuel Filter Housing Spacer; Professionally repaired instrument cluster (new steppers and lamps); Does anybody ever read this s%#t?; Injectors under warranty @ 70k; 2nd set DIY @ 155k
stevewaclo is offline
post #4 of 9 (permalink) Old 01-18-2020, 08:08 PM
stevewaclo's Avatar
Better injector diagram
Here’s a better diagram. Note ball.
File Type: jpeg 552A3CEA-66E5-41EF-8EEC-71FA57C18328.jpeg (45.5 KB, 25 views)
post #5 of 9 (permalink) Old 01-24-2020, 01:37 PM
Hey also new here. I have the same problem. First noticed it when I put an edge insight on it, wont get above 9kpsi. Immediately put a airdog raptor 4g on it to see if it would inprove, did not. Then got new stock injectors from LDS and still didnt improve. Replaced the fuel pressure regulator and also put in a race plug. I also blow air through all low pressure lines and dont feel like I have any restriction. With my experience working with high pressure hydraulics and air, I would imagine if my cp3 was bad I wouldn't be able to build up that much pressure. Any recommendations on what else to check or special test to run?
Nick821 is offline
post #6 of 9 (permalink) Old 01-24-2020, 05:23 PM
denarli6.6's Avatar
How many miles are on these trucks?
2016 LML Denali 2500
Mcgaughy's 2" drop shackle
Bilstein 5100
22x10 American Force Flux black w machined or Toyos on OEM wheels. Depends on the day of the week
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
denarli6.6 is offline
post #7 of 9 (permalink) Old 01-24-2020, 07:21 PM
On mine 310,000.
Nick821 is offline
post #8 of 9 (permalink) Old 01-24-2020, 07:33 PM
LHN...We ARE the Joneses
You had a no power condition, then you installed the monitor and saw no rail pressure?
Or you have a problem with no power after you installed the monitor?
Or the truck runs fine and the monitor is showing false data?
Hook'em_Horns! is online now
post #9 of 9 (permalink) Old 01-24-2020, 08:10 PM
Truck ran fine didnt really notice any power loss. I just bought the edge because I just wanted something to monitor everything with.
Nick821 is offline
