First Diesel, 2001 LB7 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 11 (permalink) Old 01-20-2020, 08:09 PM Thread Starter
Lb7nightmare's Avatar
installed new injectors, now im having an issue with glow plugs, the glow plug on the driver side at the back near the firewall is smoking
just looking for some direction, and some help
Lb7nightmare is offline
post #2 of 11 (permalink) Old 01-21-2020, 05:39 AM
407driver's Avatar
injector smoking? only at startup or all the time?
sounds like maybe a loose connector causing a heat build up.
407driver is offline
post #3 of 11 (permalink) Old 01-21-2020, 05:45 AM Thread Starter
I haven’t started the truck yet. I installed the injectors after I was done I went to start the truck and GLOW PLUGS STARTED TOO SMOKE
post #4 of 11 (permalink) Old 01-21-2020, 05:46 AM Thread Starter
I don’t know what else to do, I font want to an electrical fire.
post #5 of 11 (permalink) Old 01-21-2020, 05:47 AM Thread Starter
407driver thanks for responding. Much appreciated
post #6 of 11 (permalink) Old 01-21-2020, 06:37 AM
407driver's Avatar
NO, you DON"T want an electrical fire!
Is there fuel leaking from the injector nearest the smokingj GP?
It will start just fine without the GPs. You might try unplugging the Glow Plug Controller and see if it still smokes
Jwaggonersr likes this.
post #7 of 11 (permalink) Old 01-21-2020, 06:54 AM
Jwaggonersr's Avatar
If it wasnt smoking before the injector install I would think its the connector I would try cleaning the plug or replacing the electrical plug. Also clean the glow plug connection. I also use Dielectric grease on all connections. Is it on all glow plugs or just one?
Jwaggonersr is offline
post #8 of 11 (permalink) Old 01-21-2020, 07:42 AM
Is it possible you installed them with oil or fuel on your hands? If so then clean what you can see of them and see if that helps.
27 Duramax's so far!!
www.ProFabPerformance.com
We also handle S & B filters, Air Dog lift pumps, and Kraftwerks Superchargers.
Special Thanks to my Sponsors!!
Danville Performance, SoCal Diesel, Vibrant Performance, & ProFab Performance!!
RickDLance is offline
post #9 of 11 (permalink) Old 01-21-2020, 11:16 AM Thread Starter
Ok. I’ll try that ASAP thank you so much
post #10 of 11 (permalink) Old 01-24-2020, 12:56 PM
Also make sure that you didn't bend the power rail that supplies power to the glow plugs as it sits close and can short out if it gets bent. Also when I had a glow plug go out on the 2001 it would heat the power rail red hot and smoke like an electrical fire, replaced the glow plugs and all is well.
mray is offline
