02 6.6 LB7 sounds like tappet valves - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 01-25-2020, 06:35 PM Thread Starter
Hi I’m new here. I have a 02 3500 with 6.6. While running it sounds like the old gas cars with low oil. Tappet valve sounds on pass side only. Just started. Oil pressure is from idle 40 sometimes drops to 20. On acceleration goes to 60. Any ideas what might be making that noise. I appreciate all your help
Dkdamas is offline
post #2 of 3 (permalink) Old 01-25-2020, 07:53 PM
Possible exhaust leak or up pipe leak.
mray is offline
post #3 of 3 (permalink) Old 01-25-2020, 09:34 PM Thread Starter
thanks for the info. I will check them both. I really appreciate it
Dkdamas is offline
