LB7 Headgasket parts listing - Page 2 - Chevy and GMC Duramax Diesel Forum
 4Likes
post #11 of 17 (permalink) Old 04-07-2013, 11:10 AM
GarrettSanchez's Avatar
(O ) ( O) looks like that??
2001 2500HD 4x4 ext. cab long bed.
PPE boost valve, S&B intake, ported horn and y-bridge
RBP 4" to 5"tip, Driver side ex. manifold upgrade
New wielded water pump, intake heater delete
Tuned by rob at www.atptrucks.com via EFILive
Homemade cat filtration and holley lift pump
Rebuilt stock IHI at AZ turbo and tractor/HSP s475
Fresh GM injectors baby. Remaned my Cyl. heads
Custom Traction arms(fabbing up mounts)
GarrettSanchez is offline
post #12 of 17 (permalink) Old 04-07-2013, 11:10 AM
Banned
Hondarider552 is offline
post #13 of 17 (permalink) Old 04-15-2013, 02:20 PM
k thanks for the help looks like its A
post #14 of 17 (permalink) Old 04-18-2013, 10:54 AM
nice
2004 White 2500HD LLY
santanag23 is offline
post #15 of 17 (permalink) Old 01-12-2014, 09:03 PM
gmclly05's Avatar
if its not that big of a deal then why make three different thicknesses gaskets from the manufacturer??
2005 GMC 2500 LLY 108,000+ mi
4wd, CCSB, Banks ram air, EFI Live by Korey Willis,
Edge CTS monitor, Headgaskets @104,500,
ARP heads studs, S&B mouthpiece, full PPE manifolds and up pipes,
MBRP 3" down pipe, 4"MBRP front pipe,
4" exhaust, Sinister EGR delete
gmclly05 is offline
post #16 of 17 (permalink) Old 02-15-2015, 09:16 AM
need it
Originally Posted by jmaz268 View Post
1 Left headgasket
Grade A: 97309562
Grade B: 97389257
Grade C: 97389258
1 Right Headgasket
Grade A: 97309559
Grade B: 97309560
Grade C: 97309561
1 Set of ARP Headstuds: # 230-4201
Injector installation kit:
(2x)Internal Return line to head banjo seal: #97600925
(8x) Injector to return line banjo seal: #97228933
(8x) Injector copper washer: #97216082
(8x) Injector body Oring: #94011699
(8x) Injector line Oring: #94011701
1 tube of loctite Super Grey gasket maker
(16x) Injector cup oring: #94051259
(2x) External return line to head banjo seal (passenger front/ driver rear): #97600925
(1x) Fuel return line to fuel distribution block: #97250485
(2x) Coolant Ybridge to head gasket: #97223686
(1x) Heater pipe to Thermostat pipe Oring: #94011605
(1x) Upper radiator pipe Oring: #94011604
(1x) Lower Bypass pipe oring: #94011603
(1x) Upper bypass pipe: #94011602
(2x) Exhaust Manifold to Up pipe gasket: #97188685
Optional Stuff: (8x) Injector return line banjo bolt: #97228929 (Rec having a few extra, they strip easy)
(8x) Injector cup: #97188463
(3-4x) banjo seal (nice to have, used in various locations): #97600925
(1x) Turbo downpipe gasket: #97192619
(2x) Turbo pedestal to up pipe gasket: #97192618
(2x) Yrbidge gasket (highly recommend): #97251963
(2x) Exhaust manifold gasket (if manifold is removed): #98002804
(2x) lower valve Cover gasket (reusable): #97188896
(12x) hex head bolts to replace oe allen head lower valve cover bolts: ace hardware
(11x) hardened allen head bolts for upper valve cover (oe strip easy): ace hardware
Think that is everything.
John
I may need this kit if my injetcor cup didnt popped. how can i oreder them and how much..
WE GOT my duramax running TOday.
2003 duramax 6.6....
albert martinez is offline
post #17 of 17 (permalink) Old 06-02-2015, 09:53 PM
Question for you guys. Looks like my headgaskets need replaced(oil in antifreeze and previous owner removed thermostats). How likely might it be to need to replace the cylinder heads at the same time?
cs641 is offline
