baro sensor problem? - Chevy and GMC Duramax Diesel Forum
post #1 of 2 (permalink) Old 03-14-2012, 03:21 PM Thread Starter
2002 duramax, lays down going up hill and then takes off like turbo kicking in, sets MAF code and replaced MAF sensor, still sets code and only gets 11 mpg. where is baro sensor located?
running hypertech stage 3 programer, air intake and 4" exhaust
dan20 is offline
post #2 of 2 (permalink) Old 03-14-2012, 04:25 PM
You can see the MAP sensor in the photo as part #3
2005 Silverado EC/SB, LLY, 4WD, Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater
MTL_Dmax is offline
