Fuel leak - Page 4 - Chevy and GMC Duramax Diesel Forum
post #31 of 34 (permalink) Old 08-08-2017, 12:29 PM
t.ashton's Avatar
Blow by is compression gasses entering the crank case, so probable causes are cracked piston, bad rings, scored piston walls, any way the gasses can find there way out of the cylinder besides going out the exhaust stroke. Blow by usually indicates a substantial problem.
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
t.ashton is offline
post #32 of 34 (permalink) Old 08-08-2017, 01:22 PM
RdHammer's Avatar
Originally Posted by peyton4x4 View Post
Could a bad copper seal cause the blowby, or maybe a lifted cup causing the blowby? I'm thinking I may have a loose seal on the return line with a lifted cup or something wrong in the cup causing the blow by. Is there a way without a techll I can cut off one cylinder at a time?
Improperly seated cups or worn/damaged cup seals would cause blow by and I imagine the copper seal if damaged would also. You could disconnect the injectors set by set maybe and see if that would narrow down the pool. They are in pairs, and you should have 4 connectors off the harness for the injectors.
Sent from my SM-G930V using Tapatalk
01 Sierra 3500 LB7 Dually - MBRP 4" Duals...more to come soon!
RdHammer is offline
post #33 of 34 (permalink) Old 08-08-2017, 08:57 PM Thread Starter
I understand that bad rings, etc can cause blow by I've been in the mechanic business for a little while, but this is my first diesel. I know this is a lot different than the old sbc, but worn rings is something that happens over time, not out of blue one day great then next bam no compression out of nowhere. I'm really leaning towards a lifted cup/bad copper seal, I won't know for a week though. Thanks for all the help guys.
peyton4x4 is offline
post #34 of 34 (permalink) Old 08-18-2017, 05:26 PM Thread Starter
Problem ended up being a bad oring on my number 6 injector and bad return line seal. All is well now.
