DashCommand PIDs for balance rates, etc -- LB7 - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 10-04-2017, 10:10 AM Thread Starter
Downloaded DashCommand for iOS and have a WIFI ELM OBDII adapter. Bought the "Extended PID pack for 2002 GM vehicles". App connects and shows speed, hp, torque, MAF, etc, etc. But I can't get it to verify the "extended" PIDs for balance rates, fuel rail pressure, etc. which is I what I got it for. Anybody have any experience with this app or this problem? It might be important to mention that the truck had an Edge Juice w/ Attitude installed before I bought it. Could the Edge be intercepting the signals for certain things like the balance rates, etc and not sending them to the OBDII?
2002 White Chevy Silverado 2500HD Crew Cab 4X4 LS
Head studs
Fass lift pump
Banks Cold Air Intake
Edge Insight Pro CS2 monitor
Titan 52 gallon diesel tank with Beans sump
SirMatthewT is offline
post #2 of 15 (permalink) Old 10-04-2017, 10:32 AM
Shouldn't you be able to read balance rates on the Edge?
mray is offline
post #3 of 15 (permalink) Old 10-04-2017, 10:43 AM Thread Starter
I don't have a CS or CS2. I have the old Attitude with the monotone gray display. Pretty sure balance rates aren't supported. This one:
Head studs
Fass lift pump
post #4 of 15 (permalink) Old 10-04-2017, 12:56 PM
I doubt the edge is intercepting messages.
The enhanced PIDs for balance rates are 0x162F through 0x1636. The entire message should look like "22 16 2F 01" sent to the ELM327 device. I've had issues with some ELM devices not always responding because the trailing "01" is not added, telling the ELM device there is only one message expected in return so return it as soon as it's received. The other possibility is the application not telling the ELM device to set the correct header for J1850 devices, which should be "6C 10 F1" (I've had this problem with Torque lite). The default header is usually "68 6A F1", where the first byte (2 digits) is the priority mask, second the destination, and the last telling OBD the sender is from an off-board device (your ELM327 device).
Hope this helps somewhat. I'm in the process of releasing my ELM327 reader application (for PC) that reads enhanced PIDs. If I get legal clearance I'll announce it.
2005 LLY 3500 CCLB 215,000 miles
Shibby6600 is offline
post #5 of 15 (permalink) Old 09-07-2019, 12:26 PM
flynn78us's Avatar
Did you get it to work I have the same edge and can’t get the balance rates either and no help from the folks at dash command
flynn78us is offline
post #6 of 15 (permalink) Old 09-09-2019, 09:33 AM Thread Starter
No I never got it to read all of the PIDs. I suspect it's my ELM's fault but I haven't tried another or messed with it in awhile. I currently have larger issues with an engine swap and if I ever get that completed I've bought an Edge Insight Pro CS2 to read the "deeper" PIDs like balance rates, etc.
Head studs
Fass lift pump
post #7 of 15 (permalink) Old 09-12-2019, 05:17 PM
flynn78us's Avatar
I changed obd2 readers and got mine working. Hopefully you can get your squared away
2005 3500 ECLB 4x4 Auto
post #8 of 15 (permalink) Old 09-16-2019, 02:40 PM
I had found a guide somewhere to add the pids to torque. Worked.
Only issue I found, was when the app was configured to display the balance rates, it would lock my ECU up. To elaborate, The ECU in my vehicle would not go to sleep and resulted in a dead battery. This only occurs if the device and torque app are left connected. In my case, it was connected to a android device in the center console, which stayed on.
There was another app posted on one of these forums called "link". Someone wrote it, and I cannot find it anymore, but it worked flawlessly and already had the pids.
2004 Chevy 2500HD(LB7) LS Crew Cab
2015 Tow Mirrors, Lightweight Tailgate Mod (ebay replacement lol), Move Bumpers, Tuff Stuff 17,500# Winch, Amber LED Bulbs in DRL Turn/Park, 16x8 American Racing Wheels w/4.5" backspacing, 315/75r16 Mud tires, Kryptonite Tierods, Cognito Tubular Upper Control Arms & Pitman/Idler Bracing kit, Bilstein 5100 Shocks, NorCal Firewall mod, Edge Juice w/Attitude, 5" MBRP exhaust, K&N CAI with non K&N "filter", 3" Inter-cooler tubing, PPI Wastegate delay thingy, Longhorn Fab dash opening , 54" Curved Quad Row LED light bar(Violates ohms law even with 832w at less than 40amps!)
bumbalard is offline
post #9 of 15 (permalink) Old 11-19-2019, 06:50 AM
What obd2 reader did you buy? I have the GoPoint BT1 recommended by Dashcommand and it doesn't read injector balance.
chuckd83 is offline
post #10 of 15 (permalink) Old 11-19-2019, 04:58 PM
flynn78us's Avatar
Panlong OBD scanner for iOS from amazon. My gopoint didn’t work either so I tried this one and it worked. Only 15.99 hopefully the link below will work
Panlong OBD2 Scanner for iOS iPhone iPad & Android, OBDII WiFi Car Diagnostic Code Reader, Read/Clear Trouble Codes Turn Off Check Engine Light https://www.amazon.com/dp/B07BHLQLN5..._mgi1Db19DFSXG
