2004 lb7 No gauges no run - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 01-27-2019, 11:23 AM Thread Starter
Dually's Avatar
Hi everyone, new here. I have read dozens of posts with similar problems to mine but not the exact symptoms. My truck started as normal then died after 5 seconds, now have no instrument cluster at all, totally dead. truck cranks normal but no start. I have checked every fuse all good I checked all wires at ignition plug all have power, pulled the edu and nothing works. disconnected the batteries, checked them they are good. I'm out of ideas other then to hook up a scanner like a tech ll which I don't have. Any ideas ......
Dually is offline
post #2 of 4 (permalink) Old 01-30-2019, 11:35 AM
stevewaclo's Avatar
Location: Carson City, NV Proud Participant, Federal Witness Protection Program
How goes it?
By now, you probably had your ride towed to someone with appropriate diagnostic equipment.
What have you learned?
Best.
2003 GMC Sierra 2500HD SLE ExtCab CA Emissions; 155k; Allison 1000 w/Transynd X2 Flush & Fill; 8' bed; AFE/CAI; MBRP 4" Exhaust; Side Tint, 33% VLT, rear, Limo; Smittybilt Stainless Side Nerf Bars; Sprayed-in Bed Liner; MadJack Fuel Filter Access Door; Regular Used Oil Analysis (latest available on request), Blackstone Labs; EGT/Boost Gauges; Dual Chrome Dipsticks, JC Whitney; Stainless Steel fuel filter head bleeder screw; New WP and Hydroboost; Billet Aluminum Fuel Filter Housing Spacer; Professionally repaired instrument cluster (new steppers and lamps); Does anybody ever read this s%#t?; Injectors under warranty @ 70k; 2nd set DIY @ 155k
stevewaclo is offline
post #3 of 4 (permalink) Old 01-30-2019, 11:47 AM Thread Starter
Dually's Avatar
No actually I have not towed it yet, waiting for the weather to break. Will post back when I find something out.
Dually is offline
post #4 of 4 (permalink) Old 11-11-2019, 09:10 PM
Any luck?
Curtis_js17 is offline
Similar Threads
Running wires for gauges, cleanest way and best spot to run wires durtyDmax Gauges, Electronics and Wiring. 3 08-22-2015 01:50 PM
No power, no codes, no more money, no more patience, and almost no more duramax! Stevenmc89 01-04.5 LB7 Duramax Powertrain 75 05-15-2015 08:15 PM
What gauges should I run? DieselNovice Gauges, Electronics and Wiring. 0 04-14-2015 11:43 AM
2004 GMC Sierra 6.6 LB7 Balance Rates run after white smoke at idel kwkduramax 04.5-05 LLY Duramax Powertrain 3 10-31-2013 07:02 PM
2004 305/555 Cummins Vs 2004.5 LLY Torque Monster General Discussion 12 04-07-2010 02:22 PM
