looking for a vacuum hose diagram - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 04-03-2019, 11:07 PM Thread Starter
I recently replaced my egr valve on my 2003 duramax and noticed that some of the vacuum lines where decaying so we yarded them off and replaced them.... only issue is we yarded all of them off at once and now we cant figure out where each one goes. I'm at a loss. I've tried looking on YouTube and on here for diagrams but no luck if some one has a diagram that would be insanely helpful that way I can get rid of my egr stuck open code. The truck has 150k miles with new injectors, head gasket, studs etc. water pump, radiator egr, high pressure fuel lines, and I know I'm forgetting a lot. I've done a pile of work on this thing.
I'm not a gear head is offline
post #2 of 5 (permalink) Old 04-04-2019, 02:34 AM
Found this using Google search:
https://www.dieselplace.com/forum/3061953-post64.html
2003 2500HD 6.6 duramax (LB7) all stock (no mods)
MeBucko is offline
post #3 of 5 (permalink) Old 04-04-2019, 02:50 AM Thread Starter
I found that as well and tried to follow it but it is out of his truck so it is really hard for me to see what it goes to. thank you though for your help
post #4 of 5 (permalink) Old 04-04-2019, 02:54 AM Thread Starter
mebucko I will try and follow this tomorrow maybe I have it plumbed completely backwards that's why I was not able to understand it (wouldnt suprise me) lol again thank you for all your help you guys make owning a truck fun
post #5 of 5 (permalink) Old 04-06-2019, 02:32 PM
duraturd916's Avatar
i should have mine still. ill check in a few.
2004 lb7 cclb
sas dana 60
wfo radius arm kit with king coil overs
rear shackle flip
head studs
ppe tuner
5" dunno exhaust
37-12.50/17 cooper stt pro
method 305 wheels
two miles of driveshafts
auto meter factory match gauges boost/pyro
duraturd916 is offline
Similar Threads
looking for a vacuum diagram for 2003 6.6 I'm not a gear head How To's, DIY and Write ups 3 04-05-2019 04:31 AM
Fuel Hose-Heater Hose Which one to use 407driver Maintenance 0 01-08-2018 02:00 AM
Ac refrigerant vacuum hose Picster38 General Discussion 4 10-22-2017 01:46 PM
05 LLY hard upper hose and collapsed upper hose dtr2214 04.5-05 LLY Duramax Powertrain 18 07-14-2013 10:15 AM
Capped Hose Tied to Filler hose booguill General Discussion 2 06-25-2007 04:33 PM
