LB7 balance rates: Manual Transmission - Chevy and GMC Duramax Diesel Forum
post #1 of 2 (permalink) Old 06-21-2019, 07:25 PM Thread Starter
I was wondering if the balance rate ranges are the same on a manual transmission truck as an automatic? Also I read somewhere that there is a different procedure for measuring balance rates, but there was no details. Is this true, or is it just as simple as taking the reading at idle in neutral?
post #2 of 2 (permalink) Old 06-22-2019, 06:20 AM
I would think that the balance rates in neutral would be the same, there is some info out there about some figures to use to get a more accurate readings might have to google it.
mray is offline
