LB7 Injectors and Turbo - Page 2 - Chevy and GMC Duramax Diesel Forum
 3Likes
post #11 of 14 (permalink) Old 05-02-2019, 06:43 PM
What did you end up doing?
2002 LB7 5 inch exhaust, ppe boost valve, boost/egt/rail pressure gauges, fass 95
Super is offline
post #12 of 14 (permalink) Old 06-23-2019, 12:40 AM Thread Starter
Thank you everyone for your replies, they have really provided me with adequate information. I'm sorry Ive been so busy with graduating and school but anyways its summer now! I haven't done anything yet. My dad is still very hesitant to drop a big chunk of change into this 17 year old truck. But I intend to keep it for a long time, my dad bought it brand new in 2002 and I basically grew up in it. It has too much sentimental value to me to just sell it.
So, what happens if I just never replace them? What will eventually happen if I do not address the injector issue? I went to my local chevy dealer and the service department manager said to drive the truck with the injectors like that until it doesn't run anymore, which really made me till my head and look at him in weird way because I would think that would put additional wear on other components but, what do I know? He works for GM so he should know best. Also, is the blow by coming from underneath the truck and from lifting the oil cap caused by the bad injectors?
Thanks,
sglll3 is offline
post #13 of 14 (permalink) Old 06-28-2019, 08:53 AM
I have a 2002 2500hd 4x4 that I changed the injectors and turbo about 3000 miles ago, running Lincoln Diesel 45 over SAC injectors and 64mm turbo and mileage tune currently. 3" turbo exhaust down pipe with 3.5" inlet pipe and intake, Air Dog pump,PPE boost increase valve along with Banks big head waste gate valve and 4" exhaust. Turbo spools quickly and injectors made big power difference, fuel mileage is related to your right foot, but highway mileage at last 300 mile trip was 20.3. My suggestion is that if you have it pulled down for injectors I would do the turbo at the same time, you will need all the room you can get when pulling turbo. Had to custom bend up a long breaker bar with torch to get the exhaust bolts loose on turbo against fire wall, very tight, even had to use cheater bar on breaker bar. I also did injection pump fuel pressure regulator and related hoses, fuel and coolant, thermostats,along with doing valve adjustment. Good luck
[email protected] likes this.
brakod is offline
post #14 of 14 (permalink) Old 07-11-2019, 05:52 PM
Thanks,
Sure you can run it right until the last injector fails on it like he said, then you’ll be buying a whole new motor to drop in on it, I got my truck just the way you did basically and literally until parts are falling off while going down the road I’ll still keep it, save the money an do the right upkeeps on it an your kids will drive the truck
Super is offline
Similar Threads
LB7 Injectors and Turbo sglll3 01-04.5 LB7 Performance Parts Discussion 3 07-16-2019 04:31 PM
600hp LB7 on stock injectors and turbo? Twist161 Dyno Racing 15 03-05-2015 08:14 PM
Injectors,Injectors,Injectors Need advice kawikid1425 01-04.5 LB7 Duramax Powertrain 45 02-18-2009 09:24 PM
