Another LLY...Another Headgasket.. VIDEOS - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 01-17-2020, 12:37 PM Thread Starter
Alexander Swanson's Avatar
Angry Another LLY...Another Headgasket.. VIDEOS
Hey guys,
Truck has just over 200K and after about 500 Miles on the new water pump replacement, cross over pipe, new res. cap, and T stats I developed coolant pushing out of the res at idle. I haven't done any formal testing to check exhaust gasses but has all the symptoms.
Here's some videos for sh*ts and grins
Alex
Alexander Swanson is offline
post #2 of 8 (permalink) Old 01-19-2020, 08:23 AM Thread Starter
As I'm building my case for the head gasket repair, the truck has me confused slightly.
The day the coolant started pouring out of the overflow noticeably at idle was a day that I did an injector clean (Half gallon of diesel and 16 OZ of AC Delco Upper engine cleaner) and was running it at idle for 1.5 hours. This truck is an 2005 GMC LLY and my understanding is there's no injector cups on this motor.
Here is a video of the truck after a 8 hour day of snow plowing and about 150 Miles. I did not observe any coolant coming out of the res. at all yesterday. Zero low coolant lights. I did not run the truck hard at all. I think what i have is a very small head gasket issue/Weak head studs? I believe when the truck is ran hard the heads lift more than it does under normal running conditions and compromises the system until its cool again.
Let me know what you think
post #3 of 8 (permalink) Old 01-19-2020, 09:33 AM Thread Starter
EDIT to original post: Truck was known to be overfilled with coolant in the res. but was continuing to leak enough to have loss of heat at idle with continuous coolant pushing from the res.
2005 GMC Sierra 2500 HD Duramax/DSP5/Deleted/4'' Exh./K&N/Ebay MP. 200k Club
post #4 of 8 (permalink) Old 01-19-2020, 10:50 AM
ALLY Cat's Avatar
Are you sure you got all the air purged out of the cooling system? Sometimes it's really difficult to get it all purged, even when you open the bleed port on the T stat housing.
ALLY Cat is online now
post #5 of 8 (permalink) Old 01-19-2020, 11:00 AM Thread Starter
Yes Sr. At least the best to my knowledge. I've bleed the system with opening the cap a few times since, truck has great heat.
I've had two shops pressurize the system after, one, I had them do an inner tie rod, and two after I had my water pump done and both said they passes with no leaks.
This truck confusing the hell out of me.
post #6 of 8 (permalink) Old 01-19-2020, 11:04 AM Thread Starter
Is the truck suppose to have zero pressure in the coolant tank after sitting over night? In the last video I explained the truck was sitting over night after running it for 8 hours. I had a situation were I ran the truck that morning at 5AM and came back to check coolant tank pressure and had the same release as the video showed 6 hours later.
Alex
post #7 of 8 (permalink) Old 01-19-2020, 11:38 AM
ALLY Cat's Avatar
When I replaced my water pump, even though everything was purged I had to keep adding a pint or so of coolant almost daily to keep the level up to the line. Finally after about 3 weeks of daily driving it stabilized. Pressure should return to atmosphere when engine is fully cooled, there is a rubber check valve in the cap that should open up to vent the reservoir when it cools.
post #8 of 8 (permalink) Old 01-19-2020, 12:19 PM
Had to do the same thing when I did my head gaskets. A little un-nerving to say the least! Haha.
Level hasn't moved in almost a year now.
Sent from my google machine
"Stinky Pig"
2003 Sierra 2500 Crew 4x4–Charcoal Grey Metallic
325k kms and counting
LLY Head swap
LBZ full intake w/MP
Flo-Pro Downpipe
4" Straight pipe
EGR delete
PCV Re-route
EFI Live (E. Stock/30HP/60HP Tow/high idle/No start)
Edge CTS2 with EGT
AxysAssault is offline
