Stuck at 14.2 psi of boost - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 01-25-2020, 01:55 PM Thread Starter
I just finished up my head gasket job and got it running. Me problem is when I took it for a drive it will smoke way more than before, specifically at low rpm. Iím looking through everything with a scan gauge and everything looks good except the boost pressure is holding at 14.2 psi. It doesnít change at all unless I unplug the map sensor then it drops to 4 psi (so shouldnít be the wiring?). I know the whole atmospheric pressure is ~14psi thing but it doesnít change at all if I take off, idle, power brake, shut it off. I definitely donít have a boost leak big enough to this ether as it has way more power than if it wasnít getting boost at all. Should I just say f*** it and put a new map sensor on or is there something I might be missing?
Also, are the two ďmapĒ sensors the same? I might try switching them and see if anything changes.
05 2500HD 2wd Crew Cab 8í box 2nd owner
Mods:
Intake
Coming mods:
D60 sas
Tunner
(List under construction)
oldchevy4x4 is offline
post #2 of 4 (permalink) Old 01-25-2020, 03:47 PM Thread Starter
Update after messing around all afternoon. First off I am now up to speed that the two sensors are different. The did change when I switched them though so another point for it not being a wiring problem. I tried cleaning the map and tried it again and now itís reading 12.7 at idle and when I get on it it drops. Canít say I understand that one but unless anyone chimes in Iíll probably just go ahead and get a map sensor tomorrow. Which are apparently pretty pricey compared to normal maps, go figure
Mods:
Intake
Coming mods:
D60 sas
Tunner
post #3 of 4 (permalink) Old 01-26-2020, 01:24 PM Thread Starter
Next update. New MAP sensor, still have smoke and it reads 14.0 psi at idle and will climb to close to 15 if I power brake a little. Any ideas? Iím about to drive this shit box into a lake.
Mods:
Intake
Coming mods:
D60 sas
Tunner
post #4 of 4 (permalink) Old 01-26-2020, 02:24 PM Thread Starter
Well after a drive I think the map sensor problem is fixed but itís still over fueling. So Iím going to start a new thread to go with evidently a different problem
Mods:
Intake
Coming mods:
D60 sas
Tunner
