Bad clunk no first or reverse - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By SilverGorillaLML
post #1 of 5 (permalink) Old 01-26-2020, 04:54 PM Thread Starter
2005 LLY 160k stock trans
So I was full throttle on the highway getting a little rowdy and when I let off there was a big thud and the check engine like came on. I still seem to have full power no limp mode and nothing else on the dash besides the check engine light. I don’t have reverse and it seems like either first is slipping really bad or the truck is trying to start off in second gear. It’s also holding gears out pretty long. Is it something small/fixable or built trans time?
DmaxDirtbikes77 is offline
post #2 of 5 (permalink) Old 01-26-2020, 07:06 PM
SST 1953's Avatar
It is tranny time! Probably a broken planetary.
2016 CCLB Dually LML
SOLD: 2007 CCSB LBZ.
69 Camaro S/ST-S/Gas
SST 1953 is offline
post #3 of 5 (permalink) Old 01-26-2020, 09:08 PM
SilverGorillaLML's Avatar
You done f'd up A aron
AxysAssault likes this.
NIC R
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/48RE Swap/PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
post #4 of 5 (permalink) Old 01-27-2020, 06:13 AM Thread Starter
Well a little bit of update. I nursed it home and I went to move it into my garage this morning and everything seemed to be working fine. I figured I’d take it down the road and it’s shifting perfectly fine now even the check engine light is gone
post #5 of 5 (permalink) Old 01-27-2020, 06:14 AM Thread Starter
My one friend suggested the NSS acting up? But it should’ve just stuck in the gear it was in if that went bad right?
