Elm327 logging and DTC software - Page 11 - Chevy and GMC Duramax Diesel Forum
 4Likes
post #101 of 106 (permalink) Old 07-15-2019, 12:53 PM Thread Starter
Thank you for the offer, but I'm not located in California, far from it in the northern midwest. One option I may just implement to make everyone's life easier for new support items is a setting that allows you to email me the app's logs after your done. I'd get a very detailed level of logging with the ELM device, and would be similar to how I debug in person on my own vehicles.
I expect this change will cause a notification about new permissions required, mainly wifi and/or data usage to send the email, but possibly also file access to get the logs. I like being transparent about why some permission requirements exist, so this is just an fyi.
I will update with another post when it is ready, probably a week or two.
2005 LLY 3500 CCLB 215,000 miles
Shibby6600 is offline
post #102 of 106 (permalink) Old 07-15-2019, 01:19 PM
KaliMax's Avatar
Sounds like a good idea Shibby. I'll stand by for now...
Jeff
2006 GMC 2500 SLT LLY CCSB 4x4 - Bone Stock
KaliMax is online now
post #103 of 106 (permalink) Old 07-17-2019, 07:48 PM Thread Starter
New version pushed to the Play store. Should update soon for anyone that already has the app installed.
This version has a setting "Send logs to developer". It defaults to off, and will only send me mostly anonymous log data associated with the app itself and interactions with the car. I say mostly because this change will collect your VIN number in the byte encoded format. I have no interest in decoding it manually, but since the app displays vehicle info on first connection, it will inevitably collect your VIN. If you do not want this, leave the new setting turned off. New permission for the app was added to use the internet (to send the logs, of course).
Here is a view of the logs you'll be sending me. Things I'll know are which android version you're using, and the unique android ID (this ID is not tied to anything except the physical phone itself, no accounts or other apps). The unique ID allows me to differentiate what devices sent me what logs and piece them together since they are sent in batches of 500 at a time.
Code:
2019-07-18T00:59:20.775Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/MainActivity]: onCreateView: default bluetooth adapter obtained
2019-07-18T00:59:20.814Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/MainActivity]: onStart: bluetooth is already enabled
2019-07-18T00:59:20.832Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Globals]: Starting new connection thread
2019-07-18T00:59:21.546Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Elm327Cable: discovering ELM version
2019-07-18T00:59:21.554Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATZ
2019-07-18T00:59:23.123Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response:
ELM327 v1.3a
2019-07-18T00:59:23.124Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Elm327Cable: cable is ELM327 type
2019-07-18T00:59:23.124Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Elm327Cable: discovered ELM version: v1.3a
2019-07-18T00:59:23.125Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Elm327Cable: turning echo off
2019-07-18T00:59:23.125Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATE0
2019-07-18T00:59:23.132Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: ATE0
OK
2019-07-18T00:59:23.133Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Elm327Cable: setting headers to off
2019-07-18T00:59:23.134Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATH0
2019-07-18T00:59:23.146Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: OK
2019-07-18T00:59:23.147Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Elm327Cable: turning auto protocol on
2019-07-18T00:59:23.148Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATSP0
2019-07-18T00:59:23.161Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: OK
2019-07-18T00:59:23.161Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Elm327Cable: forcing a search for existing protocols
2019-07-18T00:59:23.162Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data 0105
2019-07-18T00:59:27.889Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: SEARCHING...
41 05 44
2019-07-18T00:59:27.902Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATDP
2019-07-18T00:59:27.954Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: AUTO, ISO 15765-4 (CAN 11/500)
Code:
2019-07-18T01:00:40.501Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATSH7DF
2019-07-18T01:00:40.514Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: OK
2019-07-18T01:00:40.515Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data 221154
2019-07-18T01:00:40.563Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: Receive: 62 11 54 4C
2019-07-18T01:00:40.565Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATSH7DF
2019-07-18T01:00:40.607Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: OK
2019-07-18T01:00:40.610Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data 010A
2019-07-18T01:00:40.664Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: Receive: 41 0A 64
41 0A 63
2019-07-18T01:00:40.665Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATSH7DF
2019-07-18T01:00:40.678Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: OK
2019-07-18T01:00:40.679Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data 010B
2019-07-18T01:00:40.731Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: Receive: 41 0B 3D
2019-07-18T01:00:40.732Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data ATSH7DF
2019-07-18T01:00:40.745Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [VERBOSE/Elm327Cable]: SendElmInitString: response: OK
2019-07-18T01:00:40.750Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/Elm327Cable]: Send: sending data 0110
2019-07-18T01:00:40.852Z | 1.0 : Android-6.0.1 | 9c85a1d06a4bc649 | [INFO/HYPERLOG]: Log Counts: 504 | File Size: 24161 bytes.
post #104 of 106 (permalink) Old 07-17-2019, 09:50 PM
KaliMax's Avatar
Glad to share my data with you. I've updated and signed up for being a beta tester - sounds like I already am!
Thanks again for your efforts.
Jeff
post #105 of 106 (permalink) Old 07-18-2019, 10:31 AM
I tried OBD doctor and it does not show demand for fuel or injector balance rates. The trial version did indicate that if the $ version were activated that it would plot the fuel pressure but we already have that with link, so there's no reason to try it. I did send them an email asking about demand and injector balance but I'm not optimistic.
I'll save others, I read the support for Toad Pro which is touted as what the pro mechanics use. Well notice the following.
Manufacturers/Vehicles NOT Supported: Chevrolet (Chevy), Dodge / Ram, GMC, Jeep, Land Rover, Tesla
I guess it only supports Ford
Chevrolet not supported. I suppose pro mechanics will have to get something else.
Don - WA5NGP
06 LBZ white, X Cab, Long Bed, 2WD, raised driver seat, Work Truck nuthin fancy
wa5ngp is offline
post #106 of 106 (permalink) Old 07-18-2019, 05:32 PM Thread Starter
I took a quick look at TOAD's website, I have to say I'm not impressed nor does their marketing make sense. I'm sure it has it's uses, but I would not give money to a company with that bad of marketing. Their "amazon reviews" on their website are no where to be found on their actual amazon product page, where they have two one-star reviews (out of 4 total).
