Stupid Question: coolant temps - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 17 (permalink) Old 01-21-2018, 09:30 AM
LHN...We ARE the Joneses
Originally Posted by MarvDmax04.5 View Post
SO what is the low coolant temp going to hurt?
Poor fuel mileage, no heater....or long in coming up warm air.
In hot weather/working hard, overheat/spikes possible with no coolant cycling.
Hook'em_Horns! is online now
post #12 of 17 (permalink) Old 02-01-2018, 05:46 AM Thread Starter
So I changed out the thermostats, did a coolant flush, and gauge pretty much still acts the same: low load, sits at major tick between 160 and 210. Heavy load, spikes up to 210, but gets no higher.
I towed my 5th wheel this weekend, and it held at 210, even on a grade, so I guess everything is ok. We'll see what she does once warmer weather returns.
lowmiler is offline
post #13 of 17 (permalink) Old 02-01-2018, 06:38 AM
John Deere Parts guy
DMAXfirefighter's Avatar
Like @novaman64 said, the gauges are not terribly accurate so an auxiliary monitor is a good way to see what temp the engine is actually seeing. I have a CTS2 in both of my trucks, and can tell you that the gauge on the dash shows significantly more movement than the temp actually fluctuates. My CTS2 will show a change of less than 6*, while the dash will show a fluctuation of about 25*. So if you think the gauge is moving a lot, it may not really be changing that much in reality. Also, depending on mileage and surroundings, it may not hurt to clean the cooling stack as well. Even though the coolers may look clean from the outside, they will hold a TON of gunk in the fins, and in between the radiator and intercooler. Just a thought and something to look at and think about
John Deere Service Manager
DMAXfirefighter is offline
post #14 of 17 (permalink) Old 02-07-2018, 09:53 PM
Searching the forum myself with this question. Recently i've had to put some coolant in my 05LLY and was concerned about possible failures. Changed the cap and didn't notice a change. Took it to a local diesel mechanic to check it over. He said he ran it through the gambit of tests and didn't find anything. Suggested based on mileage and age i change the thermostats. I told him to go ahead as i'm buried at work and lacking for time right now. When he did it he said the stats were in the wrong position and on top of the o-rings instead of in the slot in the o-rings. They were not gm stats.
Before the change not issues at all, ran like a top, heat, didnt overheat etc. just a little lost coolant here and there. On the way home tonight i noticed the gauge now moves between 190 and 210. It has never done this before, always sat right at 180. Still runs like a top. Something to be concerned about or is this normal behavior?
Sparkmonkey is offline
post #15 of 17 (permalink) Old 02-07-2018, 10:02 PM
novaman64's Avatar
Send a message via Skype™ to novaman64
As previously mentioned, dash gauge is totally inaccurate. Get a CTS or something else to check coolant temps with. Generally duramax's have a 180 and 185 therm, so should run around there (going up hills 190-200). On my truck, 185 (actual temp) shows as 210 on the dash gauge.
-Jimmy (aka DmaxStoreJimmy)
08' Silverado 3500HD CCLB LMM 4x4 - Build Thread
02' Silverado 2500HD CCLB LB7 4x4 - RIP 12/15/2016
#1 member 3500 LB SRW Club
WWW.DMAXSTORE.COM
DURAMAX ONLY STORE 1-877-4MY-DMAX
novaman64 is offline
post #16 of 17 (permalink) Old 02-07-2018, 10:09 PM
I have a blutooth OBDIi adapter in the truck that i use with the Torque app on my phone. On the way to work tomorrow i'll watch what the computer says. Just surprised that it was above the 180 mark and moving so much. Before it never moved once it warmed up. When i looked at the old stats they stuck open and move with moderate pressure. Maybe i should have kept them.
post #17 of 17 (permalink) Old 02-08-2018, 03:55 AM
The two T-stats are 180* & 185*....you're fine, it's where it should be.
