Clutch fan engagement - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 25 (permalink) Old 06-07-2019, 04:22 PM
CA88's Avatar
Lol. I ended up gettin my replacement bumper after I hit a deer haulin my father n laws lml on a gooseneck.
But anyways. Does anybody know long it takes on average to clean cooling stack and flip the tranny cooler?
*2007 Chevy Greystone Metallic 2500HD 4x4 CCSB LBZ
EFI Live by Idaho Rob DSP5, Transgo jr
Leveled, debagded, demolded
Thunderstruck front replacement bumper
285/75/16 Mickey Thompson ATZ P3
Atwood gneck hitch
Tekonsha Prodigy 3 Brake controller
Stock exhaust cat and muffler deleted with 5" tip
And more to come…
*85 Chevy 2500 custom deluxe sclb 4" lift
Needs a little work here and there…
CA88 is offline
post #12 of 25 (permalink) Old 06-07-2019, 06:50 PM
MarvDmax04.5's Avatar
I think it's an easy couple of hours to do a good cleaning of the stack. BUT motivation and outside temp really plays havoc on my time estimates. It's MISERABLE here in the desert SW right now so it's a easy 2-3 day 4-10 sixpack job. <grins>
2004.5 Silverado CCSB LLY
Sinister EGR delete,
S&B air box and up-sized S&B intake mouthpiece,
CAT converter delete,
ATP 5 stage tune - Edge CST w/ EGT and backup camera,
5" AFE Power full exhaust kit
Airlift 5000# bags w/ on-board remote compressor
Just a nice CLEAN stock truck for towing the toys to the playground with a back seat full of grandkids
MarvDmax04.5 is offline
post #13 of 25 (permalink) Old 06-07-2019, 07:01 PM
LHN...We ARE the Joneses
Yeah, same here. Heat index towards 110 this weekend.
Hook'em_Horns! is online now
post #14 of 25 (permalink) Old 06-10-2019, 09:20 AM
CA88's Avatar
Dang. Only n the 80’s now here. But that don’t sound bad. Just a couple hrs of work. Thanks MarvDmax
Atwood gneck hitch
And more to come…
CA88 is offline
post #15 of 25 (permalink) Old 08-01-2019, 11:40 AM Thread Starter
Newman1415's Avatar
Hey fellas, it’s been a long while since I started this thread, but I have taken my entire stack apart and cleaned it out, I was surprised what was in there.
While towing this summer on a hot day I was peaking close to 230 engine temp according to the factory gauge. The fan did no engage. And it also did not engage once all winter under the extreme cold temps during “morning sickness”.
When I was backing trailer into the house almost immediately after a steep grade my AC was blowing warm and smelt like engine compartment inside the cab. Never had those before
2005 LLY Silverado 2500HD Crewcab LT
5" MBRP Turbo back with Downpipe
Cobalt Pyro & Boost
LBZ MP - EGR Blocked
DSP 5 EFI
6" Zone lift
17" KMC Addicts
35" Nitto Trail Grapplers
www.alligatorperformance.com
Newman1415 is offline
post #16 of 25 (permalink) Old 08-03-2019, 03:42 PM
TXLLY's Avatar
i cleaned my cooling stack today. it took me about 3 hrs. My stack was not bad at all. I did not pull the radiator or drain it though. It was not easy to get the intercooler out and when I do it again next time i will drain and pull the radiator.
Jethro - 2004.5 Chevy 3500 CCLB DRW
Built by 2L Custom Trucks Poolville, Texas
S&B mouthpiece, PPE Xcelerator std, LML brake booster, ATTA Max Wedge 94 gallon auxiliary tank, 30k goosneck, 25k Demco Recon 5th wheel hitch.
TXLLY is offline
post #17 of 25 (permalink) Old 08-03-2019, 11:36 PM
I'm gonna do mine tomorrow. I'm gonna blow em out with a long nozzle for my compressor, the use the wash wand I made to fit between the rads (hopefully).
Sent from my LG-H831 using Tapatalk
"Stinky Pig"
2003 Sierra 2500 Crew 4x4–Charcoal Grey Metallic
325k kms and counting
LLY Head swap
LBZ full intake w/MP
Flo-Pro Downpipe
4" Straight pipe
EGR delete
PCV Re-route
EFI Live (E. Stock/30HP/60HP Tow/high idle/No start)
Edge CTS2 with EGT
AxysAssault is offline
post #18 of 25 (permalink) Old 08-04-2019, 07:00 AM
TXLLY's Avatar
AxysAssault, I did blow mine out with a compressor from the back too. There was a ton of dust blowing out. There is absolutely no space between the radiator and IC to put any kind of wand in between. I managed to get the intercooler out without pulling the radiator, but I fear it took more time then it would have to just pull the radiator too.
TXLLY is offline
post #19 of 25 (permalink) Old 08-04-2019, 07:46 PM
Yea I popped the top shroud off today, then realized it's gonna take a bit more time than anticipated. I'm pretty sure my air wand will fit in between (it's like a 1/4" x 2ft nozzle), but the wash wand will most definitely not. I'll just blow it all out and hit the water from the back of the rad and hope for the best haha.
I should have done this properly when I had the motor on the floor for my head swap.....buuuut it was winter.....in Canada.
"Stinky Pig"
LLY Head swap
Flo-Pro Downpipe
4" Straight pipe
EGR delete
PCV Re-route
Edge CTS2 with EGT
post #20 of 25 (permalink) Old 08-05-2019, 05:26 AM
Pretty much a waste of time trying to blow it out. Had my radiator out tried blowing first, did nothing. Laid the radiator down flat soak it down with Purple cleaner & let it sit for about an hour. Then did the rinse lather repeat. Mine was plugged in the center probably about 1/4 the surface, right where you need the airflow for the fan to work.
My fan comes on now before the factory gauge hits 210.
04 GMC LB7 2500 SAC 45 injectors DSP5 EFI live, ported air inlet. 4" MBRP droning exhaust.
77cruiser is online now
