Clutch fan engagement - Page 3 - Chevy and GMC Duramax Diesel Forum
post #21 of 25 (permalink) Old 08-05-2019, 11:34 AM
Originally Posted by 77cruiser View Post
Pretty much a waste of time trying to blow it out. Had my radiator out tried blowing first, did nothing. Laid the radiator down flat soak it down with Purple cleaner & let it sit for about an hour. Then did the rinse lather repeat. Mine was plugged in the center probably about 1/4 the surface, right where you need the airflow for the fan to work.
My fan comes on now before the factory gauge hits 210.
Damn. Well. I guess I'll pull it out then. You get pretty quick at it after 3 times haha.
Sent from my LG-H831 using Tapatalk
"Stinky Pig"
2003 Sierra 2500 Crew 4x4–Charcoal Grey Metallic
325k kms and counting
LLY Head swap
LBZ full intake w/MP
Flo-Pro Downpipe
4" Straight pipe
EGR delete
PCV Re-route
EFI Live (E. Stock/30HP/60HP Tow/high idle/No start)
Edge CTS2 with EGT
AxysAssault is offline
post #22 of 25 (permalink) Old 08-05-2019, 11:57 AM
LHN...We ARE the Joneses
Not so much.
It's easier to blow dirt than wash mud. Blowgun 1st, then water rinse, then Simple Green...let soak, but don't let it dry.
Then rinse/flush with water.
I like to finish up with air again, via the leaf blower.
Hook'em_Horns! is online now
post #23 of 25 (permalink) Old 08-05-2019, 11:57 AM
Not so much.
Then rinse/flush with water. Sometimes, it takes a soft bristle brush to remove the crust from years of neglect.
post #24 of 25 (permalink) Old 08-05-2019, 12:11 PM
MarvDmax04.5's Avatar
Echo Echo ,, Echo Echo (<grins>
Just be careful in how much air pressure and how hard you jam the wand around in there. Those fins are bent pretty easily. Folding too many fins over is just as bad as, or actually probably worse than the gunk that builds up in the core.
2004.5 Silverado CCSB LLY
Sinister EGR delete,
S&B air box and up-sized S&B intake mouthpiece,
CAT converter delete,
ATP 5 stage tune - Edge CST w/ EGT and backup camera,
5" AFE Power full exhaust kit
Airlift 5000# bags w/ on-board remote compressor
Just a nice CLEAN stock truck for towing the toys to the playground with a back seat full of grandkids
MarvDmax04.5 is offline
post #25 of 25 (permalink) Old 08-06-2019, 11:17 PM
Don't worry. This is all in preparation for the first haul through the mountains with my new HGs and head swap. I'll be gentle. Anything I can do to prevent a breakdown will make me less anxious haha. Just installed my egt probe this evening.
It's only a 7000lb camper, so should be a light test run. Turbo don't fail me now!! Haha
"Stinky Pig"
LLY Head swap
Flo-Pro Downpipe
4" Straight pipe
EGR delete
PCV Re-route
Edge CTS2 with EGT
