Turbine Input Speed Sensor P0717 - Chevy and GMC Duramax Diesel Forum
post #1 of 1 (permalink) Old 04-10-2019, 10:47 AM Thread Starter
taylorbok's Avatar
Hey all I am getting some tranny codes super intermittently. First time it happened was back at the beginning of December, pulled over and jiggled some wires, un hooked batteries and away it went so changed the one sensor when I got back and drove good all winter until last weekend it happened again, same thing unhook the sensors and batteries plug everything back in and away it goes but then it came back the next day, I pulled back as much loom as I can and can't find a broken wire, the input sensor is new. what else could it be?
When the code comes on the converter comes unlocked and tranny stays in what ever gear it's in.
All the codes I get are
P0700 Transmission Control Module (TCM) Requested MIL Illumination
P0717 Input/Turbine Speed Sensor A Circuit No Signal
P0726 Eng Speed Input Circ Range/Perf
C0035 Left wheel speed sensor
C0040 Right wheel speed sensor
B0229 HVAC actuator circuit
I have heard the wheel speed sensors could be related to the tranny codes but not sure what the cause is, any input would help.
I might change the other sensor on the tranny just to eliminate that. I am also going to pull back more of the loom and look over all the wires completely.
04.5 Chevy LLY Dually
Sinister EGR delete, PCV reroute. S&B intake with mouthpiece, 5" straight pipe, ATP tunning, Edge CTS insight, 6" Zone lift, 35" tires, FASS 165 lift pump, FASS suction tube, Titan tan.
taylorbok is offline
Similar Threads
P0717 - Stuck in 1st or 3rd griebaar Transmission Shop 1 06-25-2015 01:45 PM
HELP replaced TCM and Speed senser(p0717) and still having Issue msudmax 01-04.5 LB7 Duramax Powertrain 8 11-27-2014 07:26 PM
Trans problems P0716 P0717 levig14 Transmission Shop 11 08-01-2014 06:57 AM
Input Speed Sensor - P0716 griebaar 07.5-10 LMM Duramax Powertrain 5 06-14-2014 03:37 PM
need help with a 4L60E transmission turbine speed sensor pmdickso Transmission Shop 0 07-06-2009 09:16 AM
