Fuel filter head leaking. - Chevy and GMC Duramax Diesel Forum
 8Likes
post #1 of 15 (permalink) Old 04-15-2019, 09:25 AM Thread Starter
rta1197's Avatar
A few months ago, I replaced the seals in the fuel filter head assembly. Now I have a leak from under the primer that I can't seem to stop.
I've taken it off two or three times to make sure there were no cracks, no dirt and the o-rings wasn't crooked.
I've been able to slow it down but not stopped.
Is there something I'm just missing?
Bob Anderson
From my Galaxy S9+ using Tapatalk.
From the Texas Panhandle
LLY GMC CC SWB 2500 HD 4x4
Bully Dog intake (existing)
Resonator deleted
EGR deleted
PCV re-routed
MBRP 3" downpipe
FASS LP & filters
PPE Race Fuel Valve
Stock rims with 265/75R16 Cooper S/T Maxx
rta1197 is online now
post #2 of 15 (permalink) Old 04-15-2019, 10:19 AM
Just buy a new filter and head. They come as one unit, about $135. No one can tell where your filter head might be leaking without seeing it.
rta1197 likes this.
Ron Nielson
Ron Nielson is offline
post #3 of 15 (permalink) Old 04-15-2019, 10:24 AM Thread Starter
rta1197's Avatar
That's kinda what I figured. I can't see where the leak is. I just didn't want to spend the money unwarranted.
Thanks
Bob Anderson
Resonator deleted
EGR deleted
PCV re-routed
MBRP 3" downpipe
FASS LP & filters
PPE Race Fuel Valve
post #4 of 15 (permalink) Old 04-15-2019, 01:03 PM
Shanester's Avatar
I was in the same boat. I just decided to remove the factory fuel filter instead. It seems to be working just fine.
rta1197 likes this.
2006 LBZ S.B.C.C. LT 4X4
Cognito 4" NTBD
EFI LIVE with DSP5 Thanks Mark
Danville Stg. 2 GT3794 Thanks Mark
Built tranny with Limitless 1078 Thanks Mike and Evan
Shanester is online now
post #5 of 15 (permalink) Old 04-15-2019, 01:20 PM Thread Starter
rta1197's Avatar
I've thought about doing that as well.
Bob Anderson
Shanester likes this.
Resonator deleted
EGR deleted
PCV re-routed
MBRP 3" downpipe
FASS LP & filters
PPE Race Fuel Valve
post #6 of 15 (permalink) Old 04-15-2019, 03:03 PM
SouthCo's Avatar
For $135 Iíd prefer to have a new fuel filter head and a way to prime as opposed to deleting it...
rta1197 likes this.
2007 2500HD LBZ GMC Sierra Classic Crew Cab SLT 4WD
MBRP DP Back 5" Exhaust
MBRP DP
LB7 right side up pipe
SouthCo is online now
post #7 of 15 (permalink) Old 04-15-2019, 03:06 PM
Shanester's Avatar
He has a way to prime it.
rta1197 likes this.
Cognito 4" NTBD
post #8 of 15 (permalink) Old 04-15-2019, 03:14 PM
SouthCo's Avatar
Guess I missed that from his post. Didnít mention his setup and I donít see it via tapatalk. Still deleting the filter head makes little sense over $135... the stock setup provides a great way to separate water from the fuel. But itís not the only way so to each their own...
rta1197 likes this.
MBRP DP
post #9 of 15 (permalink) Old 04-15-2019, 03:30 PM
LHN...We ARE the Joneses
Until the lift pump fails....then it's the tow truck shuffle.
rta1197 likes this.
Hook'em_Horns! is online now
post #10 of 15 (permalink) Old 04-15-2019, 03:31 PM
Shanester's Avatar
Fass is in his signature. It makes perfect sense to me. Cleans up the engine bay a little bit and lift pumps also provide a great way to separate water from the fuel. I do agree with you on the "to each their own" though...
rta1197 likes this.
Cognito 4" NTBD
Similar Threads
fuel filter head leaking awake1630 06-07 LBZ & LLY Duramax Powertrain 3 06-28-2016 01:54 PM
Leaking filter head after adding lift pump skifox 04.5-05 LLY Performance Parts Discussion 20 10-21-2015 04:38 PM
Filter head assembly leaking after lift pump install? 9mmkungfu 01-04.5 LB7 Performance Parts Discussion 12 03-28-2014 10:41 AM
Filter head leaking Gunpilot 04.5-05 LLY Duramax Powertrain 2 11-19-2012 09:53 AM
