LLY sensor location? - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 05-20-2019, 09:46 AM Thread Starter
KJD
KJD's Avatar
I need help! Im nearly done a cp3 swap and have all the wiring and plugs reinstalled except one sensor (looks identical to the map sensor). It's located on about 6" of wire just before the two connectors that clip together with the plastic levers on the driver's side. I can't for the life of me find a place to plug this thing in.
KJD is offline
post #2 of 6 (permalink) Old 05-20-2019, 01:03 PM
DaveLLY's Avatar
Picture would help but it sounds like you're talking about atmospheric pressure sensor. Snaps in under bale connector bracket. Vane position sensor connector is just outboard of placement (white wire).
2016 Denali
2005 CC Sierra - 366k and strong, Son's ride now (but I'm not signing over title just yet)
DaveLLY is offline
post #3 of 6 (permalink) Old 05-21-2019, 03:48 PM Thread Starter
KJD
KJD's Avatar
This is the sensor
KJD is offline
post #4 of 6 (permalink) Old 05-21-2019, 03:50 PM Thread Starter
KJD
KJD's Avatar
I'm new to this forum thing. Thanks for the help. Any chance I can get a picture showing where this goes?
KJD is offline
post #5 of 6 (permalink) Old 05-21-2019, 03:59 PM
BlownL36's Avatar
That’s the baro sensor. Drivers side valve cover. Goes on the bracket the the vane position sensor is on.
04.5 CHEVY 2500HD CC/SB LT-Green, 2" Leveling Kit, Bilsteins, Wicked Wheel 2, Boost Stick, 4" MBRP Turbo Back w/ 5" tip, LMM Resonator Box, Airdog LP, PCV reroute, Airbox Mod with AFE Filter, LBZ MP, Fleece Tapshifter, EGR Delete, Edge CTS2, Mishimoto Trans Cooler, EFI Live Tuned/ Idaho Rob,5% tint, 260K and still going strong,
BlownL36 is offline
post #6 of 6 (permalink) Old 05-21-2019, 07:31 PM Thread Starter
KJD
KJD's Avatar
Originally Posted by BlownL36 View Post
Thatís the baro sensor. Drivers side valve cover. Goes on the bracket the the vane position sensor is on.
Thanks for the help! I didn't realize it just plugged into the bracket.
KJD is offline
Similar Threads
LLY sensor location?! KJD 911 Problems Forum 0 05-20-2019 09:44 AM
LLY sensor location? KJD Gauges, Electronics and Wiring. 0 05-20-2019 09:42 AM
2004 Duramax LLY oil sending sensor location Corvair1 Maintenance 5 08-25-2017 04:49 AM
IAT sensor location? b.fil85 Gauges, Electronics and Wiring. 0 06-26-2009 05:02 AM
Engine Crank Sensor Purchase Location? torquemaster Transmission Shop 1 01-30-2009 09:24 PM
