LLY Injector Miss w/ Balance Rates - Chevy and GMC Duramax Diesel Forum
 2Likes
post #1 of 12 (permalink) Old Today, 06:52 AM Thread Starter
Greetings All, I have a 2005 LLY that I recently purchased and got running, although poorly, it is running. I have an issue that I need help with. I pulled the Balance Rates using my OTC Genysis Evo and it is as follows:
Cyl 1 -1.9
Cyl 2 -1.9
Cyl 3 15.0
Cyl 4 -1.9
Cyl 5 6.0
Cyl 6 15.0
Cyl 7 -1.9
Cyl 8 -1.9
Actual Fuel Rail Pressure 6334.1 psi
Desired FRP 6235.0
I took that data and swapped out some used injectors to see if I could isolate the problem and the balance rates are
Cyl 1 -1.6
Cyl 2 -1.6
Cyl 3 15.0
Cyl 4 5.5
Cyl 5 15.0
Cyl 6 15.0
Cyl 7 -1.6
Cyl 8 -1.6
Actual Fuel Rail Pressure 6465.
Any input would be greatly appreciated.
HankMinion is online now
post #2 of 12 (permalink) Old Today, 06:56 AM Thread Starter
I also forgot to mention that I have codes PO300C Engine Missfire Detected, Code PO303C Cylinder 3 misfire detected, PO305C Cylinder 5 misfire detected, PO306C Cylinder 6 misfire detected, P1229C Injector 3 Output circuit, and P1238C Injector 6 output circuit as well as P2227C Barometric Sensor Performance. Any Ideas,
post #3 of 12 (permalink) Old Today, 07:12 AM
rta1197's Avatar
Have you tried running a concentrated dose of injector cleaner?
Bob Anderson
From my Galaxy S9+ using Tapatalk.
From the Texas Panhandle
LLY GMC CC SWB 2500 HD 4x4
Bully Dog intake (existing)
Resonator deleted
EGR deleted
PCV re-routed
MBRP 3" downpipe
FASS LP & filters
PPE Race Fuel Valve
Stock rims with 265/75R16 Cooper S/T Maxx
rta1197 is online now
post #4 of 12 (permalink) Old Today, 08:31 AM Thread Starter
I have not but will gladly try. Any thing in particular you recommend?
post #5 of 12 (permalink) Old Today, 09:05 AM
rta1197's Avatar
Diesel Kleen is usually available at Walmart and it's good. I've used it but have switched to Hot Shot's Secret. Might try their Diesel Extreme.
The Diesel Kleen jug that does 250 gallons all at once or the entire bottle of Diesel Extreme.
May not fix all the problems. But definitely should help the balance rates.
Bob Anderson
Resonator deleted
EGR deleted
PCV re-routed
MBRP 3" downpipe
FASS LP & filters
PPE Race Fuel Valve
post #6 of 12 (permalink) Old Today, 10:14 AM
ieetgluu's Avatar
Ya certainly looks like dirty/plugged injectors
Sent from my SM-N920V using Tapatalk
Chad
04.5 4x4 ~160k miles
DE 4", 5100s, LBZ MP, S&B LBZ air, KoryWillis Go-go Juice, Insight CTS, ADII, 8' Fisher, Highroller Ultimate Idler Arm, Profab delete, XD RareParts tie rods
Dirtymax this, Dirtymax that... :taunt
ieetgluu is online now
post #7 of 12 (permalink) Old Today, 10:17 AM
Might try searching "ice pick fix".
ieetgluu likes this.
mray is offline
post #8 of 12 (permalink) Old Today, 10:19 AM
rta1197's Avatar
I agree...those connections may be getting loose and/or weak.
Bob Anderson
Resonator deleted
EGR deleted
PCV re-routed
MBRP 3" downpipe
FASS LP & filters
PPE Race Fuel Valve
post #9 of 12 (permalink) Old Today, 10:54 AM
ieetgluu's Avatar
But if you're swapping injectors and it follows then it's likely the injector
rta1197 likes this.
Chad
post #10 of 12 (permalink) Old Today, 10:59 AM Thread Starter
Thank you all for the replys. I will pick up some injector cleaner this afternoon. I tried the ice pick on the plug ins on the affected plugs and no change. The injectors I swapped were from a running core motor with a bad crank, so I am not sure if they were in fact good. To see no deviation in the ones with the return rates pegged at 15 (cyl 3 and 6) is what had me questioning a circuit problem and etc. I also checked the FICM harness so see if there were any rub areas and they was not any. Thanks again for the quick replys.
